Did you update the entity IDs to match that of your config?
Looks like you would need the yr weather platform loaded.
A group of all your windows and a notification setup is all required.
Doesn’t - platform: state need to numeric_state?
alias: 'Raining and windows are opened'
platform: state
entity_id: sensor.weather_symbol
to: '10'
condition:
platform: state
entity_id: group.windows
state: 'on'
service: notify.telegram_ihaus
title: "Window open"
message: "raining and the windows are opened"
when I run a hass --script check_config
2017-11-23 13:07:10 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: expected str for dictionary value @ data['trigger'][0]['to']. Got None
extra keys not allowed @ data['condition'][0]['platform']. Got None
extra keys not allowed @ data['condition'][0]['state']. Got None
required key not provided @ data['condition'][0]['condition']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
I change it to:
- platform: state
to: '10'
condition:
- platform: state
state: 'on'
- service: notify.telegram_ihaus
still throwing an error I can’t work with:
2017-11-23 13:19:24 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [platform] is an invalid option for [automation]. Check: automation->condition->0->platform. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
alias: needs to be - alias: then you will need to reformat for 2 extra spaces throughout.
true in general, but when you run a automation: !include_dir_list automation
@Juergen did you give it a try? All my automations are in different files and the all start with a -
either - id
or - alias
Your condition should have another condition:
line.
platform: state
to: '10'
condition:
condition:
platform: state
state: 'on'
