I have a problem with the ultrasonic sensor in my watertank giving very unstable readings when the sun is on the tank, i guess the humidity and temp inside tank are very high then. How would i force the sensor only to be updated at say midnight?
The sensor is an nodemcu based ultrasonic sensor running via esphome, i know you can set sample rate duration in the nodemcu but i want sample time.
I also tried setting up a time triggered input_binary sensor but couldnt get the syntax right to copy the actual sensor reading to it.
I would use a filter on your sensor that only passes the value on at certain times during the day otherwise it would just pass the current state. Solution requires time: component be used to provide current time if youâre not already using that of course.
If I only wanted something done at a certain time, I wouldnât use a sensor, Iâd use an automation and one or more input_[number, text, boolean] values to which I could set my value(s).
Where are you getting the data for the input/sensor?
Edit: I havenât actually done this, but the more I think about it, the more I think itâs actually not possible. Sensors are the only things that âgetâ, so I donât think you can do this in an automation.
I like @micqueâs solution of having a condition in the value_template, but that doesnât stop the sensor from retrieving the value to be run through the template as often as it ever did. You wonât actually be able to control when it tries to retrieve its value, itâs just that the state will only change based on the templateâs time condition.
value_template: >
{%- if (states('sensor.time') > "13:00") and (states('sensor.time') < "14:00") -%}
{{ some new sensor value }}
{%- else -%}
{{ states('sensor.whatever_sensor_this_is_so_the_value_remains_unchanged') }}
{%- endif -%}
Use a lambda filter which allows you to create an if then else statement. Iâm out of pocket right now but can create a sample for you when I get home if you would like.
Yea, I dont necessarily need to stop the sensor retrieving values, this work around will work.
But as I am still a bit of a noob its the syntax of what goes here {{ some new sensor value }} where I am stuckâŚ
Sure, your syntax may not be perfect, but it helps me to get the idea of what you want to accomplish. Seeing this, Iâd go back to my original suggestion of just taking the sensor value at 23:00 and sticking it in an input field, either input_number or input_text depending on what type of value that sensor has.
input_number:
tank_sensor:
name: 'Water tank sensor value at 23:00'
automation:
- platform: time
at: '23:00:00'
- service: input_number.set_value
data_template:
entity_id: input_number.tank_sensor
value: '{{ states("sensor.tank_sensor") }}'
Invalid config for [input_number]: required key not provided @ data[âinput_numberâ][âtank_sensorâ][âmaxâ]. Got None
required key not provided @ data[âinput_numberâ][âtank_sensorâ][âminâ]. Got None. (See /config/configuration.yaml, line 282). Please check the docs at https://home-assistant.io/components/input_number/
I just wrote that off the cuff I guess I didnât define some required attributes for the input_number. You should read that documentation it links to.
Then create a time component. This one runs off the HA clock
time:
# time based on Home Assistant time
platform: homeassistant
timezone: "whereever"
Then in the ultrasonic sensor code do the following (filters is the focus here)
- id: water_tank
platform: ultrasonic
trigger_pin: 25
echo_pin: 26
filters:
lambda: |-
auto now = id(ha_time).now(); // local time
if ((now.hour >= 22 && now.hour < 6) || id(first_read)) return x;
else return id(water_tank).state;
id(first_read) = false;
So what this will do is from 10pm to 6am the sensor will send the actual reading through to be published to HA. The rest of the time the sensor will send the stored value (probably the value read at 6am). The first_read boolean ensures that you get at least one reading no matter when the system starts. If you need to do some additional processing on the reading âxâ you can add any math you want before returning the value;
If you decide to pursue this and need some additional help let me know. Otherwise for future coding itâs a great technique for allowing test data to be injected into your system through a sensor.
