The imported configuration enables web_server. However, I have been experiencing stability issues with these plugs and I would like to try disabling it. I am looking for some incantation which I can add to my configuration which will disable web_server in the expanded output I see when selecting 'Validate`.
I have already whispered the following into the void without result:
web_server: {}
and
web_server:
port: null
The latter I tried because the imported configuration only defines port, but the expanded configuration contains more. I wondered if I could explicitly unset port and avoid the setting of anything else, but it had no effect at all.
I can obviously just fork the imported configuration, but I was hoping to avoid that. Any ideas?
Just copy whole yaml from that “imported” file to your yaml, remove “web server” and you’re done. And, of course, remove “packages…:” lines. I always do that way - i hate “imported” stuff, because i don’t know what’s going on and what i have configured… it becomes kinda “black mystery box” with unknown stuff inside…
True, but if you can’t do that then this is simple and quick solution, correct?
Not all can be done …like i have a “common” file for all my esp’s with definitions that all esp’s must have, then i just include common file in my yaml. But, if i put “api” definitions there it won’t compile (reports an error). So i just simply put api in each of my api and voila.
This looked promising, but afaict you can only !remove if you used !include, which I didn’t because it’s a remote repo.
The docs do say:
Since packages are incorporated using the !include system…
and they don’t exclude remote packages from that. I suspect this is either possible with some unintuitive or undocumented syntax, or nearly possible with some code tweaks.
