I’ve been trying to setup my Enervent LTR-5 Z with an eAir controller via Modbus TCP in Home Assistant. I’ve managed to add all the sensors and basic temperature settings successfully, see configs below.
I am however stuck at parsing the bitfields. I’ve gotten to the point where I am able to parse the status register as an unsigned short integer, but I suspect that this is not the correct approach. The documentation states;
Bit 0 indicates Max cooling mode, bit 1: max heating. Bit 2: Machine is stopped due to A alarm. Bit 3 indicates the machine has been stopped by request (ie. not due to alarm condition). Bit 4: indicates Away state. Bit 5 is reserved. Bit 6 indicates temperature boosting, bit 7 CO2 boosting, bit 8 RH boosting, bit 9 manual boosting. Bit 10 overpressure mode, bit 11 cooker hood mode, bit 12 central vacuum cleaner mode. Bit 13 indicates cool-off period of electrical heating coil. Bit 14 indicates summer night cooling mode. Bit 15 indicates heat recovery wheel defrosting mode. Value 0 indicates “normal” state, no special status is active.
How can I split the bitfield in Home Assistant? My initial thought was just to convert it into a integer, and use a template to map the numbers to a sensible device status, but is there a better way?
I just had an Enervent Salla with eAir controller installed, so this is super useful for me too.
Modbus integration in Home Assistant can be activated by adding the device specific lines to your configuration.yaml.
So, basically copy-paste that configuration.yaml bit that bkvamme shared above to your HA config.yaml, but do remember to change the host address to match your Enervent Pingvin’s IP.
Then create the other configuration files that bkvamme shared in the same folder.
Test the modified configuration (in Developer Tools / YAML and, if everything was ok, Restart Home Assistant.
You should now have the sensors and switches that are defined in the new config files.
I did exactly that (and also changed LTR5Z to Enervent from the config files), and now I can see those sensors and switches. The temperature readings match those that the eAir panel displays and, for example, turning “Silent mode” on from Home Assistant, I can see the status change also on the eAir panel.
Thanks to bkvamme for saving me the trouble of figuring out how to configure this stuff on Home Assistant!
Not a silly question at all, i did not find any switch where to enable/disable it ? Just found a settings for it, and they all were for serial connection (1,19200, n) ?
EDIT: Ok, it seems that i have too old software version in my eAir:/
Ok, on my side it shows “eAir SW version: 2.14”.
Did you manage to get it upgraded?
If you go to: Main menu > Settings > System configuration
Do you now have Modbus settings at the end of the list? (second last item)
Under Modbus settings, the last setting is Modbus TCP. I think this settings was “off” by default.
Hmm, bummer!
Did they specify how those updates can be done? I mean, I don’t see any option to trigger that from either the eAir controller or through my.enervent.com.
Have you guys checked the physicall state of the eAir controller battery ? After 3years, mine is allready swollen a bit, so i took it out. Works fine without, in its gradle of course.
I heard that this is common problem and some have had burning controllers etc…
Then I created a template sensor with attributes for each mode, using the bitwise_and filter:
- sensor:
- name: "Enervent status map"
state: "{{ states('sensor.enervent_status') }}"
attributes:
max_cooling: "{% if states('sensor.enervent_status') | int | bitwise_and(1) %}on{% else %}off{% endif %}"
max_heating: "{% if states('sensor.enervent_status') | int | bitwise_and(2) %}on{% else %}off{% endif %}"
stopped_due_to_alarm: "{% if states('sensor.enervent_status') | int | bitwise_and(4) %}on{% else %}off{% endif %}"
stopped_by_request: "{% if states('sensor.enervent_status') | int | bitwise_and(8) %}on{% else %}off{% endif %}"
away_mode: "{% if states('sensor.enervent_status') | int | bitwise_and(16) %}on{% else %}off{% endif %}"
temp_boosting: "{% if states('sensor.enervent_status') | int | bitwise_and(64) %}on{% else %}off{% endif %}"
co2_boosting: "{% if states('sensor.enervent_status') | int | bitwise_and(128) %}on{% else %}off{% endif %}"
rh_boosting: "{% if states('sensor.enervent_status') | int | bitwise_and(256) %}on{% else %}off{% endif %}"
manual_boosting_mode: "{% if states('sensor.enervent_status') | int | bitwise_and(512) %}on{% else %}off{% endif %}"
overpressure_mode: "{% if states('sensor.enervent_status') | int | bitwise_and(1024) %}on{% else %}off{% endif %}"
cooker_hood_mode: "{% if states('sensor.enervent_status') | int | bitwise_and(2048) %}on{% else %}off{% endif %}"
I’ve only tested Away mode, Manual boosting & overpressure modes, as those can be directly enabled from the panel. But given the bit order, the other states should work just the same.
Based on the verified logic it’s then easy to create template sensors for individual modes.
For example:
Hmm… for some reason my Enervent modbus connection dies after a day or so. Reloading modbus from developer tools does not help, only restarting homeassistant works ?
2022-11-30 09:21:52.760 ERROR (SyncWorker_8) [homeassistant.components.modbus.modbus] Pymodbus: enervent: Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)
I haven’t had much luck with reloading modbus yaml through Developer Tools either. Seems like you need to restart Home Assistant every time you make some changes to the config.
Haven’t had any disconnection issues on my end but, with a previous version of Home Assistant the connection was lost when I tried to reload modbus yaml.
Not exactly.
I’m using a vertical stack to group all things related to the Enervent ventilator. I have button cards mapped to those switches (modbus coil registers) for the preset modes I expect to be using.
Here’s a screen shot.
I recently change to HASS OS, and there restart via developer tools work. I Also learned that there is service to restart modbus connection. I was wondering if its possible to make automation to check whether connection is up or not, and use that modbus restart service. I just dont know how to check if connection is up…
