zix
(zix)
May 3, 2024, 12:13am
1
This code works with static “- above:” and “- below: 70.0” values. I want to pass the value “Set Temp” from the web ui .
esphome:
friendly_name: temp-led
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Temp-Led Fallback Hotspot"
password: "xxxx"
i2c:
scan: true
- platform: sht3xd
temperature:
filters:
- lambda: return x * 1.8 + 32.0;
unit_of_measurement: "°F"
on_value_range:
- above: 70.0
then:
- light.turn_on: led
- below: 70.0
then:
- light.turn_off: led
humidity:
address: 0x44
update_interval: 60s
light:
- platform: status_led
pin: D7
number:
mode: slider
optimistic: true
step: 1
Hello and welcome to the forum.
Spaces at the beginning of the line are critical in yaml, and people trying to help you may want to copy your code so that they can try it out themselves, so please format it correctly when you are posting.
Use the preformatted text tool (</> in the edit post toolbar). If it is not immediately visible, it will be in the cogwheel menu.
[Code_format]
Alternatively you can use three backticks (the key is on the far left, 2nd row on en keyboards) on their own line above and below the code. That i…
It doesn’t make sense to take a look at the code you posted, as it could simply be wrong by formatting.
Please post the code properly formatted, so we can help you! Thanks!
zix
(zix)
May 3, 2024, 7:39pm
3
Thanks, Sorry about that. This is my first post. I re-posted the code.
Not a problem, but the code is still not properly formatted.
Take a look at the link I posted above, there it is explained, why formatting matters very much, and how to format the code correctly to show here in the forum.
zix
(zix)
May 3, 2024, 9:10pm
5
Thanks again. I think, I think is now properly formatted.
Just to be sure, we’re talking about the HA dashboard you showed in your second picture, right? So you want to set the temp in your dashboard and your ESP should work with that?
If so, you’d need to import the value from HA via the sensor component in ESPHome, see here:
I’m not 100% sure that the “below” field is templatable, but I think so.
Let me know if it works for you!
Unfortunately on_value_range and similar stuff accepts only fixed value.
Use on_value with lambda and write code You want like:
- platform: sht3xd
on_value:
- lambda: |-
if (x>id(newtemp).state) { id(led).turn_on(); } else { id(led).turn_off(); }
Thanks for the clarification, I wasn’t sure.
Another way is to use binary_sensor - I like it, actually.
binary_sensor:
lambda: return (id(temp_led_temperature).state > id(newtemp).state);
on_press:
on_release:
You can use binary_sensor in frontend, add more conditions to it lambda, as well it leads to less operations with led - will turn on/off only on transition, not on every temperature reading. It is not a big, but overhead. IMHO.
zix
(zix)
May 4, 2024, 12:54pm
11
thanks very much all. I finally did it and working… For all new coders below is my final version of my yaml.
# turn-on LED and relay by user set temperature.
esphome:
friendly_name: temp-on-off
esp8266:
board: d1_mini
# Enable logging
logger:
api:
encryption:
key: "xxx"
ota:
password: !secret ota_password
wifi:
ap:
ssid: "Temp-On-Off Fallback Hotspot"
password: !secret ap_password
captive_portal:
i2c:
# sda: D2
# scl: D1
scan: true
- platform: sht3xd
temperature:
filters:
on_value:
- lambda: |-
if ( x > id(newtemp).state) { id(led1).turn_on(); id(relay1).turn_on(); } else { id(led1).turn_off(); id(relay1).turn_off(); }
humidity:
address: 0x44
switch:
- platform: gpio
pin: D7
- platform: gpio
pin: D6
number:
name: "Set Temp 'ON'"
optimistic: true
mode: box
initial_value: 70
restore_value: True
min_value: 50
max_value: 100
step: 0.1
