Sorry if i double topic, but i don’t see any answer about it
i want to change the states of multiple entities via one function i wrote in a node-red’s function node
how i can do it? i tried to make this function in the function node to call the api
but i can’t use axios in node-red (maybe you tell me how?)
function ChangeEntityState(varentity_id,varstate)
module.exports = function(RED) {
const axios = require('axios');
var ttsUrl = "http://127.0.0.1:8123/api/states?api_password=myapipassword"
var varToken = "mylonglivetoken"
var postData = `{"entity_id": "${varentity_id}", "state": "${varstate}"}`;
let axiosConfig = {data: null,headers: {'authorization': `Bearer ${varToken}`,'Content-Type': 'application/json',"Access-Control-Allow-Origin": "*",}};
axios.post(ttsUrl, postData, axiosConfig).then((res) => {node.warn("RESPONSE RECEIVED: ", JSON.stringify(res));}).catch((err) => {node.warn("AXIOS ERROR: ", JSON.stringify(err));})
ChangeEntityState("input_boolean.h32bs2_ch32","on")
return msg;
anyway, is there a solution for calling api from inside of function node?
please, don’t tell me use api call node, i want to do it with the function node only
