I’m working on setting up the HA-Overseerr integration in Home Assistant. I’ve installed it from HACS, and can see that it created 3 new scripts:
How can I enter a TV show into a Text Helper, and then call the the Submit TV Request script to start downloading it?
For example, let’s say I want to download the TV Show “Loki”. I would basically want to be able to enter Loki into the Text Helper from Lovelace to have it call the overseerr.submit_tv_show script.
Under Developer Tools, I’m using this example data, but it just shows “unknown”. Not sure if this is an issue with the integration…or if I’m just formatting the request incorrectly.
service: overseerr.submit_tv_request
season: latest
I’m going to assume it’s something to do with the integration, as I see this in the logs. The documentation doesnt state if I need to manually create these entities or not, but I wouldn’t assume so?
