This may be a simple question. I have a Rhasspy Intent which passes a value to Home Assistant. The variable passed from Rhasspy is {{ContainerToCheck}}. I can confirm this works with a simple Speech/Text Action. Here is the intent script:
CheckDocker: # Intent type
speech:
text: Checking Docker State {{states("sensor.docker_check")}} {{ContainerToCheck}}
What I would like to do is pass that value to a rest sensor appending the variable at the end of the URL:
- platform: rest
resource_template: http://xxx.xxx.x.x:8126/container/{{ContainerToCheck}}
value_template: '{{ value_json.status }}'
However, this does not need to pass any value to the resource_template. Does anyone know how to either debug this or pass an intent driven value to dynamically generate a REST call like this?
