Hi All,
I have a simple mqtt demultiplexer (from OMG Pilight to individual mqtt sensors).
Its goal is convert messages like this
{“message”:{“unit”:50555,“battery”:1,“state”:“closed”},“protocol”:“GS-iwds07”,“length”:“”,“repeats”:2,“status”:2}
to this
home/contacts/1st_floor/window Closed
home/contacts/1st_floor/window/attribute {“battery”: “Normal”}
Currently I pass the data to my python_script individually:
- service: python_script.pilight2mqtt_contact_demux
data_template:
protocol: "{{ trigger.payload_json.protocol }}"
code: "{{ trigger.payload_json.message.unit if trigger.payload_json.protocol == 'GS-iwds07' else trigger.payload_json.message.unitcode }}"
state: "{{ trigger.payload_json.message.state }}"
battery: "{{ trigger.payload_json.message.battery if trigger.payload_json.protocol == 'GS-iwds07' else '1' }}"
As you can see, I had to add some logic when passing code and battery variables.
I would like to do all the processing in the script by passing the whole trigger.payload_json.message
to it like this:
data_template:
message: "{{ trigger.payload_json.message }}"
but it doesn’t work, seems like variables’ content gets converted to a string because I can see the following in the HA log
Executing pilight2mqtt_contact_demux.py: {‘protocol’: ‘GS-iwds07’, ‘message’: “{‘unit’: 50555, ‘battery’: 1, ‘state’: ‘closed’}”}
and obviously anything like message.unit
in the script yellds None
So I wonder if there is a way to pass a Python dict (as far as I understand what trigger.payload_json
is) to python_script
as a dict, intact?
Or is there another approach to achieve my goal?
UPDATE:
it works if I DO NOT use template in automation, i.e
data_template:
message: {'state':'closed'}
Apparently the result of every template is a string (and dicts get converted to strings) and there is no way to pass run-time dict into a script without templates.
There is also no easy way to convert that string into a dict as import
and eval
are prohibited within python_script
Is that it then?
