How to play a sound through the RPI speaker with Hass.io?
Is it possible play a sound through the RPI speaker with Hass.io?
How would one do that?
thanks,
chris
I never did something like this, but maybe this is a solution: Play audio file for door announcement
Thank you for the tip Recte. Indeed, this seems like something that may work
I added the mopidy addon
When i start it, I get:
OSError: [Errno 2] No such file or directory: '/share/mopidy/playlists'
I’m not sure where the add on is looking for that directory, and/or if it is mapped from inside the container to the host
I’ll open a separate question for that
thanks
chris
SOLVED:
Additional info on how to add/configure the mopidy AddOn:
In my setup the share directory was expected to be under /usr/share/hassio/
(All those different deployment models are quite confusing for a simple newbie like myself)
sudo mkdir -p /usr/share/hassio/share/mopidy/playlists
sudo mkdir -p /usr/share/hassio/share/mopidy/media
chrisV
Hi, all
Currently running home assistant on a RPI4 and for some reason I got consistently stuck in the installation of mopidy (apparently no release candidate for ARM and the custom repos weren’t working for me), so I ended up finding this rather simple solution using a community VLC plugin that I hope will help someone else.
  1. Supervisor > Addon Store > Add custom repository hassio-local-vlc/local-vlc at master · rodripf/hassio-local-vlc · GitHub and install the add-on.
    The GIT includes detailed instructions on setting it up. Make sure to enable telnet and define a password in the addon-config section.
  2. Add this line to your configuration.yaml
media_player:
  - platform: vlc_telnet
    host: 127.0.0.1
    password: whateverPasswordYouSetBefore
  1. Restart Home Assistant.
At this point you should have a working entity called VLC-TELNET. You can rename it by adding a “name” property to the config.
You can now play TTS using the media dashboard component and even better you can playback MP3 or WAV files by calling a service as shown below.
Please note that media files need to be uploaded to the /share folder (you can use the samba add-on to upload the files there).
Happy automating fellas!
Hi, thank you for the solution. So far this is the only working solution for rpi 4. My home assistant havily relay on tts for feedback. This year I have upgrade from rpi 3 to rpi 4. Before I was using mopidy, and it was working fine. But I have a problem with this (vlc) addon. When starts to read/speak the message for the first 4 or 5 seconds the sound is very choppy. Some times I can not hear whole words. I have changed the sd card for ssd. My rpi 4 has 8 gb of ram. Do you have the same problem?
Yeah, I noticed the same issues after the setup and thought it could be my audio files. I worked around it by putting 1 second of empty space before the beginning of the audio files. Then I found that wav 44Khz exported from Audacity didn’t stutter so much but it’s hit and miss.
Gays, I found a mopidy version that is compatible with Raspberry Pi 4. Now the tts is smooth. In order to install it you need to add this repo: GitHub - Poeschl/Hassio-Addons: The repository for my Home Assistant Supervisor Add-ons.
I tried it for my rpi4 too but it seems there’s a problem with the output device, showing dummy output and I don’t listen anything. Any suggestions?
I followed your instructions but it is not working, I tried uninstalling and installing again. modifying the config but no luck. could it be unsupported?
I have a raspberry pi 3. could that be the reason?
[0000007fa80e1980] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[0000007fa80e1980] main interface error: no suitable interface module
[0000007fa822cb50] main libvlc error: interface "dbus,none" initialization failed
[0000007fa80e8040] main interface error: no suitable interface module
[0000007fa822cb50] main libvlc error: interface "globalhotkeys,none" initialization failed
[0000007fa810a9e0] main playlist: playlist is empty
[0000007fa80e8040] [http] lua interface: Lua HTTP interface
[0000007fa80e1ae0] [telnet] lua interface: Listening on host "telnet://:4212".
missed this part
" Run a VLC player on your hass.io installation.
Control it using the web interface or with the new VLC Telnet component and control the player from your HA Automations!"
I installed the VLC Telnet Component and it works now after installing local VLC first
Edit:
It even works though HDMI out
I didn’t have to do anything to my config file and it worked.
