thanks for your reply. but it is still playing Fly 92.3 instead of Fly FM.
Sorry to hear. I can easily switch between them, here via picture cards:
type: custom:layout-card
layout: vertical
cards:
- type: picture
image: /local/images/93790flyfm.jpg
tap_action:
action: call-service
service: media_player.play_media
service_data:
media_content_type: custom
media_content_id: play Fly FM Radio on TUNEIN
entity_id: media_player.echo_office2
- type: picture
image: /local/images/331a23e27388d2869ed81e7480474b53.jpg
tap_action:
service_data:
media_content_id: play Fly 92.3 Radio on TUNEIN
or play them at different locations:
Not sure, but can it be a cache issue?
Can we play a stream url using Alexa as media player ??? I have tried like shown below but it isnt working… Kindly guide…
media_content_id: https://19993.live.streamtheworld.com/SKYRADIO.mp3
media_content_type: url
entity_id: media_player.echo_dot
Here is code for SiriusXM radio, Tune-in, and iHeartRadio…
- type: SIRIUSXM
id: play kiki lounge
icon: mdi:radio-tower
- type: TUNEIN
id: play fly fm
icon: mdi:radio
- type: custom
name: 93.3 The Wolf
id: play the wolf on iheartradio
icon: mdi:radio
The problem with Alexa and the methods shown in this thread is that it replicates what a vocal command would trigger.
In my case, if I say “Alex, play Frequence 3 on Tunein”, it’s going to play “Frequence 3 Urban”, not the “regular” Frequence 3 (Frequence 3 has different streams)
So this method is not precise enough I’m afraid.
In this video, the guy shows how to play a stream (taken from https://www.radio-browser.info/) but on a Chromecast, not on Alexa.
So I’m still looking for a way to :
- play a stream
- on group of Alexa speakers
Well, to 98% it works and is reliable.
When I replied to masterkenobi and tried the station he mentioned, it immediately worked for me, but not for him. I believe it is/was more or less a cache (or other) problem on his side, this sometimes happens and can’t be solved within HA or an integration.
Shortly after that I myself had problems with playing some of my stations via Tunein. Alexa claimed it don’t know what to do. So I waited a couple of days and all was fine again. But sometimes problems won’t get solved at all by waiting.
There can be lots of reasons outside HA why things sometime aren’t working as expected.
Anyway, I gave it a quick try with your three stations: by using picture cards its just a copy & paste of the code and adjusting the station names and icons - it worked immediately without a problem here:
Aside from the icons in the upper controls (Badges), you can see from the descriptions that the right stations are playing.
But you may need to try different approaches.
For Fréquence 3 it works here with simple using
media_content_type: TUNEIN
media_content_id: Fréquence 3
for Fréquence 3 Dance or Fréquence 3 World I need to use
media_content_id: play Fréquence 3 World on tunein
First off, thank you for your long answer.
I am aware that the problem may lie somewhere between Alexa and TuneIn and not on HA’s side.
I had a funky behavior a few months ago when I requested the French RTL radio and that Alexa suddenly started playing a German radio also called RTL something with no changes on my side and after months if not years of success. It came back to the French station a few weeks later out of the blue (this behavior was confirmed by other French Alexa users with no clear explanation)
Hence my need to try play a stream rather than the name of the station
I tried your code a couple posts above and the more recent one to obtain this :
layout: vertical
cards:
- type: picture
image: https://demo.home-assistant.io/stub_config/t-shirt-promo.png
tap_action:
service_data:
media_content_id: play Fréquence 3 on TUNEIN
entity_id: media_player.office
- type: picture
tap_action:
service_data:
media_content_id: play Frequence3
The results are baffling to the least…
With media_content_type: custom
, HA would play randomly either the Dance stream or the Urban stream after I hit the button a couple times ! (never the regular one that I am hoping)
With media_content_type: TUNEIN
, it never works even after trying different syntaxes.
- with Fréquence3 or Frequence3 (no space, with oor without the accent) : Alexa responds “I cannot play that on TuneIn”
- with Frequence 3 (with a space) : Alexa responds “What do you want to hear ?”
I’m not sure how you made it work with media_content_type: TUNEIN
If I replace the radio name like so, it works like a charm :
media_content_id: play RTL
proving that the problem comes from that specific Frequence 3 radio (not sure the space in the name is the culprit)
So still no dice for me to play the regular Frequence 3 radio
Hi Jerome,
if you use media_content_type: TUNEIN
don’t use play
if you use media_content_type: custom
use the whole string: play station_name on TUNEIN
Always use the syntax as it is shown in Tunein, for example, if you search for Frequence3
in Tunein you’ll get this (all station names):
because it is seems not to be a clear search phrase.
But if you search for
Frequence 3
you got exactly one station only with this name:I also found Fréquence 3 FM
→ there and using this as name works as expected too.
Anyway, sometimes the results are not to understand. If I use Fréquence 3 WORLD
I got this:
Regarding the group playing: different from the Spotify integration, playing on Alexa multiroom groups is not working. You need to use a stereo group and address a member of the group or use the APP.
I would make a view with all possible methods and wait a week or two if none is working. As said sometimes it solves problems.
Good luck.
Thank you !
media_content_id: Fréquence 3 FM
did the trick and does play the original Frequence 3 stream !
You’re welcome & good to hear.
Enjoy!
I got my TuneIn stream working on an Alexa group based on what we discussed above !
Here is a script :
alias: "Media : play Frequence 3 on Downstairs"
sequence:
- service: media_player.play_media
media_content_id: Fréquence 3 FM on Downstairs # <= I have a group of a couple Alexa speakers called Downstairs
enqueue: replace
entity_id: media_player.living # <= this Alexa speaker exists but will be ignored !
mode: single
icon: mdi:play
(this trick above is explained on a documentation and I read a few days ago but cannot put my hands on)
I can launch it from this card :
type: custom:mini-media-player
entity: media_player.downstairs
tts:
platform: alexa
entity_id: media_player.downstairs
shortcuts:
buttons:
- type: script
columns: 2
show_source: icon
sound_mode: icon
source: icon
artwork: material
info: scroll
toggle_power: true
volume_stateless: false
group: false
Thanks for sharing, but no luck here.
You might got it from there?
I have three stereo groups and one multiroom group (called Dinnerparty
) which incl. all three stereo groups and three standalone Alexas.
The idea of it IMO is to address one of the standalone Alexa to play on the multiroom group Dinnerparty
, like
media_content_id: Fréquence 3 FM on Dinnerparty
enqueue: replace
entity_id: media_player.echo_show_5
But as expected (I tried something similar before) it don’t work. The answer is “I didn’t find any station with the name Fréquence 3 FM on Dinnerparty on TUNEIN” - the whole string of media_content_id
is transferred as the station name.
Yes, that’s the link I had in mind ! (" Play in Alexa groups")
What if you try a different stream with no space/no accent in it ?
Are you saying that your Dinnerparty group has groups in it ? like nested groups ?
What if you try with a “simple” group of standalone speakers ?
Yes, sure. I have three stereo groups: living room (incl. a Sub), dining room and in my office. Alexa allows to nest them in multiroom groups and everything is working fine, when played from the Alexa App or from Spotify to any of this groups.
I don’t know. Wouldn’t make sense here to only group the kitchen Echo and the Echo at the shower to a group. And as long an Echo is in a stereo group it can’t used in another group anymore.
The Alexa integration also don’t allow me to address the stereo groups directly. As described in the link, I have to address one of its member to play for example on the stereo group in my office (without mentioning the group name anywhere like you did) - echo_office2 is a member:
- type: picture
image: /local/images/jfk.jpg
tap_action:
media_content_id: Jazz Funk Soul Radio
I believe its a limitation of the integration, because as I wrote before, its different with the Spotify integration, where I can address any group directly.
Hi all, I have a similar but different problem. Up until a month or so (can’t really be exact cause I haven’t listened to that radio station) my Otvoreni radio played without issues using this:
- type: custom
id: play Otvoreni on tunein
Now it just says “I cannot play that on TuneIn.” And weirdly, I have no problems with starting that radio station directly on my Alexa.
Does anyone know what could be the reason? Other radio stations (and I have around 30 of them all play without issues.)
this might be not much of help, but well: it works here.
Anyone got any suggestions. I’m using Alexa Media player to summon a radio URL through the Radio Browser Skill but am not getting the artwork at all. Any views on how I might get it? The sound works fine though.
Could you please explain how did you get alexa to play a radio station through the browser skill? I thought you can only play it through Tune in!
if you use a custom ID, it basically just sends the command as if spoken to Alexa. So I have eg:
buttons:
- type: custom
id: tell radio browser 45
image: [link to radio logo URL]
TuneIn is too frustrating:
a) It can’t deal with foreign language station names via Alexa
b) The ads.
Radio Browser gets round that. Downside is it seems you don’t get the stream art.
Thank you very much for your time. What you stated about Tune in, is exactly what I am facing now. Could please point me where to learn more about your example and how to create all of that? Thank you.
