How to points requirements in manifest.json to a github repo
Wanted to make some changes to the Renault integration. I copied everything to custom_components, changed the domain and some more and verified that I could load the integration and trigger actions.
I made some necessary changes to the renault-api python library, but how do I test the integration in the custom_component without first publishing the python package ?
I modified manifest.json and updated the requirements to:
"requirements": [
    "renault-api @ git+https://github.com/xxxxx/renault-api.git@85fd5a4d3460f1040b65fd90eed79c9feb2ecf7d"
However, when restarting HA it is not picking up the new version of the api. I’m sure the syntax is correct, because a pip install git+https:// is able to install the correct version.
How should i do this ?
Thx in advance !
I normally install the api into my dev environment with
pip install -e [path to api]
And set the new version in the manifest file. Then as you modify the api, it will update.
Thanks for your reply!
But how does that work ? Right now using the addon to develop the code. For this I would need to get into the docker container I guess ?
@msp1974 Thank you! You have no idea how much this helped me.
@devastator I know this is over a year late but just for others that come across this. Yes, you have to run this from within the container (assuming running HAOS).
docker exec -it homeassistant sh -c 'pip install -e /config/temp/alexapy'
docker restart homeassistant
