My HA is doing great, but I came across one problem. I have automation that is checking temperature of my heating boiler. When it is above 64 deg.C. it will turn on yeelight with effect ‘Police’ to warn me about this. Now I’m thinking of revoking this alert which would be simple automation with lets say below: 60 conditions. However I also have other automations for this particular yeelight bulb. For example it will turn on when sun goes down, etc. Now, temperature of water rarely goes above 64, so my automation that would turn off light with alert would also still turning off this bulb whenever will be lit and water sensor below 64. Hope You get the problem
Is there a way to somehow write some exclusion like "turn off when below 60 only when automation with above 64 was turned on no more than 5 minuts ago’ or something like this or any other aproach.
My current automation for alert.
alias: ‘Mrugaj lampa kiedy temperatura powyzej 64 stopni’
hide_entity: True
platform: numeric_state
entity_id: sensor.temperatura_wody_w_kotle
above: 64
I can turn automation off from automation? Neat! So I guess automation that starts alert should also turn on automation for revoking it, then automation for revoking after turning off light should turn off itself?
yes, you can turn off automation (by automation.turn_off) and turn it on (by automation.turn_on). This includes the automation itself. I’ve got a automation that runs only one time after restart hass (Trigger Event/homeassistant_start won’t work for me) and than turn itself off. Another automation turns off/on multiple automations after switching an input_boolean on the frontend.
Sorry, I have to raise this topic again because I beginn to disbelief my complete development knowledge.
The situation: I’m controlling HUE-Scenes with an Input Select -so far ok
That works.
But sometimes, somebody changes the light via alexa or via Hue app. Then I want to set the input_select to ‘Manual’
That is the task of this automation:
service: input_select.select_option
entity_id: input_select.livingroom_scene
option: “manuell”
That works as well.
In order to avoid, that this automation runs everytime I initiated as a first solution a variable and set it to 1 in the beginning of first automation. The condition avoids that the second automation runs.
So far so good — but: As soon as I reset the variable in the end of the first automation, the second trigger fires.
I tried then alternatively switching off the second automation, Input_booleans and a delay. Anytime, I reset the situation, the second automation is fired. A delay of 2 minutes fires the second automation exactly after 2 minutes
The last try was, to start a timer, in oder to leave the first automation. another automation resets the input_boolean when finished. The result: read above.
Now, I have definately no idea. What is wrong?
Solved: It works without changing anything with the timer. I guess, that the timer finalizes the first automation and so that the second trigger starts and recognizes the boolean.
