I recently installed a lot of power outlet plugs to better monitor my power usage. All of these power plugs also function as switches. I would like to prevent HA from making changes to the state of some of the switches (i.e. because my refrigerator and my router are attached to them), while still displaying the state and measuring power consumption. Is there a way to accomplish this?
I currently have setup an automation that immediately toggles the switch back on, but the power interruption is still annoying. And in the case of the switch for my router, toggling it back on with HA doesnāt work, becuase the damn router is now down.
Is there some kind of āchild lockā setting? I have Tasmota and Zigbee plugs and some of them have this, but it will depend on the manufacturer. There may also be a start up setting to cater for genuine power outages.
Otherwise, I wouldnāt have thought HA should be turning off sockets spontaneously - it will only do it if youāve told it to! You might try adding a ādo not turn offā attrubute to the switch entity with customize, then you can add a condition to your automations/scripts so that fridge and router sockest are left alone.
There is a āchild lockā setting! I thought this would prevent manually switching on the physical device itself, but Iāll check if it works for switching from HA too.
You also had the right intuition: My motivation here is to prevent accidental changes. I created an automation and selected the wrong switch ā¦ my router spontaneously powering down several times a day was not fun.
I already experimented with a custom attribute, but you have to check this in every single automation, script or dashboard that you create. It also doesnāt help you at all if you put the wrong switch in a scene, since you cannot check the attributes there.
It would be really cool if I could tell HA ādonāt mess with that thingā. I think it would be usefull not only for switches.
This is really not a configuration I would do. All smart plugs eventually fail. When it fails consider the impact. So like on a router, it fails, you lose internet, not the end of the world. If itās on your furnace, and it fails, and the house freezes up and pipes burst thatās super bad. Same with a sump pump. A fridge is someone in the middle, how important that is to you is up to you. Just always consider the failure modesā¦
For these kinds of loads consider using a non-invasive CT clamp either in the breaker box or in an external box next to the plug. That gives you the reliability of being hardwired (50 year life expentancy) and current monitoring vs a 2-5 year life expectancy for a zwave switch.
@PeteRage & @complex1
This is excellent advice! Iāll try to replace at least some of these critical switches. The appeal of the power plugs is the ease of installation, because Iām really bad with tools. Looks like Iāll have to make some new experiences and get my hands dirty
