I did setup a binary sensor connected to the USB output of the TV to monitor on/off state of my TV. When TV is on there is 5V on the USB.
There is also a switch that uses an IR transmitter to toggle the state.
When I switch on the TV from the HA, there is no problem. The esp32 picks up the “On” state immediately. However, when I switch off, the power to USB is still on for about 2 to 3 seconds. This makes the switch toggle between the states on the frontend. I tried adding a delay on the turn off command, I tried publishing the state manually for the turn off command but neither of them worked.
Is there any other smart way to do this?
Here is the code:
# Monitor TV State
binary_sensor:
- platform: gpio
pin:
number: 34
mode: INPUT_PULLDOWN
# IR Switch
lambda: |-
if (id(tv_power_status).state) {
return true;
} else {
return false;
turn_on_action:
- remote_transmitter.transmit_lg:
data: 0x20DF10EF
nbits: 32
turn_off_action:
data: 0x20DF10EF
nbits: 32
- lambda: |-
id(tv_power_status).publish_state(false);
