How to print from within lambda code to the log
To troubleshoot ESPHOME code I can print to the logger without any problem. My challenge is to print to the logger from within lambda code blocks? I have read the logger component, but that doesn’t bring me any further. Below my code block where I want to print: logger.log: “write to the log: Temperature too high” The command obviously works outside the lambda block, but I can’t find what it needs to be within the lambda code block.
    on_time:
      - seconds: 0
        minutes: '*'
        then:
          lambda: !lambda |-
            auto time = id(homeassistant_time).now();
            if (id(CV_Floor_Pump_Temp_In).has_state() >= 44)
              id(Relay01).turn_off();
              logger.log: "write to the log: Temperature too high"
              id(CV_Floor_Pump_TemperatureTooHigh).turn_on();
Thanks in advance
ESP_LOGD
ESP_LOGD is indeed what you are looking for, however documentation seems to be missing. The page on lambda magic contains an example.
Syntax seems to be:
ESP_LOGD(TAG, MSG)
with the TAG being a string that shows up between brackets, followed by the line number, and MSG being the message string, which can be a formatted string.
Example:
Code inside lamda:
151        ESP_LOGD("display lambda", "your message here");
Log:
[22:24:14][D][display lambda:151]: your message here
