I have a PZEM-004+NodeMCU monitoring the overall house consumption, this works fine. I recently installed an inverter (MPP Solar) through which the house will run. There are some solar panels and a battery with it’s own BMS (JK-BMS).
For MPP Solar I fixed and installed the ESPHome integration, I get real-time wattage but no long-term data. I assume this is needed for “Energy” integration.
For the BMS I did not manage to find a cable yet, but it will also get an ESPHome treatment. It has a running total for amp-hours but not sure how to directly convert that to Wh.
I could perhaps buy another PZEM unit and integrate that but I would basically need to monitor 4 values: PV voltage (0-400V), PV current (0-18A), Battery voltage (30-50V) and current (0-150A). Not sure what my options are.
On top of the above, the inverter is using about 30-60W on its own, this will need to be subtracted/added somehow.
