I am making a refrigerator controller using a lily TTGO board (esp32, lcd) I want to configure my screen for either F or C temperature display.
I configure some Dallas temperature sensors. Then use a filter to do the conversion based on a flag.
I would like to change the “unit_of_measurement” as well, but that tag only accepts strings and, as much as I beat upon it, I could not figure out how to change that in yaml, or lambda per suggestions from ChatGPT (!). So I eventually rummaged around the sensor.h file and found a handy public method “set_unit_of_measurement()” which works fine.
So, is this a feature or a bug that !lambda cannot be used with the “unit_of_measurement” tag?
e.g. this works
filters:
- lambda: if (id(bFarenheit)) return x * (9.0/5.0) + 32.0; else return x;
- lambda: id(freezer_temp).set_unit_of_measurement(id(bFarenheit)?"°F":"°C"); return x;
This does not unit_of_measurement: !lambda id(bFarenheit)?"°F":"°C");
Believe the reason is that in HA the measurements are stored and used for historical data. If unit changes, would mess up sensor’s historical data. And yes, I know that you ask how to change, not why it doesn’t have native support for changing.
Not an option for you to add an additional sensor, so one for C and one for F and let your screen switch between those?
