How to properly remove z-wave device?
I’n all the other systems I’ve used z-wave devices, you initiate the removal at the hub, then press a button, etc on the device. Well in HA, that process seems to do nothing.
Settings > Devices & Services > Z-Wave > My Device > Delete immediately yields…
Like HA is not even searching/waiting for the device to start the un-enroll process.
This is also true in HA.
This is just a manual way to cleanup old devices, meant for a rather obscure case for Z-Wave. It might work for other integrations.
https://www.home-assistant.io/integrations/zwave_js/#integration-configuration-panel
Use the “REMOVE DEVICE” button from the integration config panel and proceed as usual.
Thank you! Can’t see the forest for the trees.
