As the title says, how do I propose a change to the frontend and backend. I could checkout the backend myself as I do know python, make the change and push it back but I don’t have the skill to do the necessary frontend changes. The thing is, it’s a simple change, at least for the backend
The objective is for the alarm panel and the backend function that tells the frontend, whether to show the user a code entry panel (numeric or alphanumeric) or no code entry panel at all. I want to decide this in the backend function code_format
based on the currently logged in user (only available in the frontend). So I need the frontend to send the currently logged in user to the backend.
Backend:
In file homeassistant\components\alarm_control_panel
in class AlarmControlPanelEntity
Change it from this
class AlarmControlPanelEntity(Entity):
"""An abstract class for alarm control entities."""
@property
def code_format(self):
"""Regex for code format or None if no code is required."""
return None
Adding , user = None
like this
@property
def code_format(self, user = None):
return None
This will keep it backwards compatible to existing versions
I need someone in the Frontend community (the developers) to help send in the current user information structure in to code_format
. The user
could be as simple as a string name but I would prefer that it is the User
class from homeassistant\auth\models.py
Can anyone out ther help please
