Tried my first EspHome project with MQTT. Sensor states are published when they change (binary sensor), but nothing is published at boot.
How can I force the sensor states (all) to be published on start instead of waiting for a change ?
Appreciate your help !
Thx,
Deva
JTPublic
(JT)
October 11, 2019, 2:43pm
2
Would the update_entity service work from the backend?
That might work, but I want to make it work without HA too. It should work OK if HA is down …
glmnet
(Guillermo Ruffino)
October 11, 2019, 3:03pm
4
It should work out of the box with api any reason not using it instead of mqtt
Using a lambda call you can force an update, you’ll have to trigger it somehow, like an automation when mqtt gets connected, unfortunately I don’t know much about mqtt to assist you more.
I would have expected it to do it automatically though.
You should be able to put something int he “on boot” of ESPHome config:
Something like below - but to get status, you would probably need to make a template… and you would have to do it for each sensor… :
esphome:
on_boot:
priority: -10
then:
- mqtt.publish:
topic: !lambda |-
if (id(reed_switch).state) return "topic1";
else return "topic2";
payload: !lambda |-
return id(reed_switch).state ? "YES" : "NO";
Not very pretty… but I think that would work.
I’ll look and see if I can find anything cleaner…
DeadEnd
