You should be able to put something int he “on boot” of ESPHome config:
Something like below - but to get status, you would probably need to make a template… and you would have to do it for each sensor… :
esphome:
on_boot:
priority: -10
then:
- mqtt.publish:
topic: !lambda |-
if (id(reed_switch).state) return "topic1";
else return "topic2";
payload: !lambda |-
return id(reed_switch).state ? "YES" : "NO";
Not very pretty… but I think that would work.
I’ll look and see if I can find anything cleaner…
DeadEnd
