I am using the InfluxDB add-on from the Home Assistant OS add-on store. I have an InfluxDB “measurement” called “state” which is in the database called “homeassistant”. Now, I am familiar with the InfluxDB CLI, and I can access the measurement data no problem. I can use the command
“USE homeassistant”, which now tells the CLI to deal with only the database “homeassistant”. Then I can access the data by using “SELECT * FROM state”, as follows:
Now I want to retreive the data from the measurement state using this user interface which shows in the sidebar after installing the add-on. If I try to “SELECT” measurements in this user interface, it complains that I haven’t chosen the database (like I did via the “USE” command when going through the CLI above):
What’s the standard way of accessing your data through this InfluxDB user interface?
Thanks!
