kouny
May 20, 2025, 12:26pm
1
I have an ESPhome device which (according to logs) connects to the wifi in 0.2 seconds (static IP, BSSID provided without scanning needed). However, it takes 15 seconds or so to show up in HA and as result an HA automation triggered by the online presence takes as much.
trigger: state
entity_id:
- switch.led_attic_q1_quinled_deca_light
See the logbook:
LED-attic Restart changed to May 20, 2025 at 14:23
14:24:00 - Now
LED-attic Restart became unavailable triggered by action Button: Press
14:23:39 - 21 seconds ago
That’s 21 seconds for a restart, even if the bare connection to the wifi is well under a second. Other times maybe it takes “as little as” 11 seconds, but usually 15 s.
In the terminal, upon uploading the firmware, I also see:
INFO Successfully connected to led-attic @ 192.168.xxx in 15.528s
INFO Successful handshake with led-attic @ 192.168.x in 0.082s
Since I use ESPhome to control lights upon power-up, I would like to speed up the starting of automation.
What can I do?
This is the config:
esphome:
friendly_name: LED-attic
on_boot:
- priority: 600
then:
- light.turn_on:
brightness: 33%
esp32:
board: mhetesp32devkit
framework:
type: arduino
logger:
baud_rate: 0
api:
encryption:
key: xxx
ota:
- platform: esphome
password: xxx
wifi:
manual_ip:
static_ip: 192.168.xxx
gateway: 192.168.xxx
subnet: 255.255.255.0
dns1: 192.168.xxx
networks:
- ssid: !secret wifi_ssid
bssid: xxx
priority: 2
bssid: xxx
priority: 1
ap:
ssid: "Led-Attic Fallback Hotspot"
password: xxx
captive_portal:
web_server:
one_wire:
- platform: gpio
pin: 32
- platform: dallas_temp
switch:
- platform: gpio
pin: 2
inverted: True
output:
- platform: ledc
pin: 16
frequency: 19531Hz
- platform: ledc
pin: 17
frequency: 19531Hz
- platform: ledc
pin: 18
frequency: 19531Hz
light:
- platform: monochromatic
default_transition_length: 2s
output: LED_gpio_16
initial_state:
state: ON
color_mode: brightness
brightness: 55%
output: LED_gpio_17
initial_state:
state: ON
brightness: 55%
output: LED_gpio_18
initial_state:
state: ON
brightness: 33%
button:
- platform: restart
Karosm
(Karosm)
May 20, 2025, 12:56pm
2
Can you substitute that automation with esphome automation?
kouny
May 20, 2025, 1:25pm
3
I can try, but the fact that ESPhome logs show
is not very promising.
I used:
api:
encryption:
key: xxx
on_client_connected:
- logger.log:
format: "Client %s connected to API with IP %s"
args: ["client_info.c_str()", "client_address.c_str()"]
- lambda: |-
if (id(ha_motion_rear).state) {
id(central).turn_off();
id(rear).turn_on();
if (id(ha_motion_office).state) {
id(office).turn_on();
binary_sensor:
- platform: homeassistant
internal: True
entity_id: binary_sensor.xxx
internal: True
but it doesn’t seem to work at all.
Karosm
(Karosm)
May 20, 2025, 1:40pm
4
Not what I meant, but doesn’t matter, I see now that automation is about other devices not connected to Esphome.
Many people use MQTT, but I wonder if HTTP request could be an option as well?
kouny
May 20, 2025, 1:43pm
5
I’m trying MQTT and it’s visibly faster. Still not clear why the native API are so slow.
Karosm
(Karosm)
May 20, 2025, 1:51pm
6
I don’t know, but it depends on home assistant which makes the connection.
kouny
May 20, 2025, 2:23pm
7
I was optimistic, it was only variability. It can be as slow as the API.
Karosm
(Karosm)
May 20, 2025, 6:21pm
8
Have a look how HA can receive HTTP requests. Esphome can make them very quickly as soon as wifi is working.
Another option coud be to send HTTP request to another “always on” esphome device which then updates HA.
Mikefila
(Mike Fila)
May 21, 2025, 12:32am
9
If you connect the node to a pc and flash it through usb, setting logging at VERY_VERBOSE
you could see what is going on in the esp during those 15 seconds. May give you some insight.
If you disable encryption, is it the same? If it is the same and the logs are of no use, you can use wireshark to see what is going back and forth to HA during those 15sec.
You have tried ESP-IDF Framework?
kouny
May 21, 2025, 8:47am
11
I didn’t think about it, but I read it’s slower.
kouny
May 21, 2025, 8:57am
12
This did it!
Now I know the cause is the wifi, it’s performing a full scan even if I provided specific networks and BSSIDs specifically hoping to get the fastest connection speed.
[10:35:35][C][wifi:048]: Setting up WiFi...
[10:35:35][C][wifi:061]: Starting WiFi...
[10:35:35][C][wifi:062]: Local MAC: 58:BF:25:8B:C8:D4
[10:35:35][V][esp32.preferences:059]: nvs_get_blob('1325887575'): ESP_ERR_NVS_NOT_FOUND - the key might not be set yet
[10:35:35][V][wifi_esp32:081]: Enabling STA.
[10:35:35][ 423][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
[10:35:35][V][wifi_esp32:523][arduino_events]: Event: WiFi ready
[10:35:35][ 520][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
[10:35:35][ 520][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
[10:35:35][V][wifi_esp32:534][arduino_events]: Event: WiFi STA start
[10:35:35][W][component:157]: Component wifi set Warning flag: scanning for networks
[10:35:41][ 6646][V][WiFiGeneric.cpp:381] _arduino_event_cb(): SCAN Done: ID: 128, Status: 0, Results: 13
[10:35:41][ 6646][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 1 - SCAN_DONE
[10:35:41][V][wifi_esp32:528][arduino_events]: Event: WiFi Scan Done status=0 number=13 scan_id=128
[10:35:41][D][wifi:497]: Found networks:
[10:35:41][I][wifi:541]: - '_ssid_' (xxx) [redacted]▂▄▆█
[10:35:41][D][wifi:542]: Channel: 1
[10:35:41][D][wifi:543]: RSSI: -53 dB
[10:35:41][I][wifi:541]: - '_ssid_' (yyy) [redacted]▂▄▆█
[10:35:41][D][wifi:542]: Channel: 6
[10:35:41][D][wifi:543]: RSSI: -77 dB
[10:35:41][D][wifi:546]: - '_ssid_'[redacted] (zzz) [redacted]▂▄▆█
[10:35:41][I][wifi:313]: WiFi Connecting to '_ssid_'...
[10:35:41][V][wifi:315]: Connection Params:
[10:35:41][V][wifi:316]: SSID: '_ssid_'
[10:35:41][V][wifi:319]: BSSID: xxx
[10:35:41][V][wifi:349]: Password: '...'[redacted]
[10:35:41][V][wifi:354]: Channel: 1
[10:35:41][V][wifi:361]: Manual IP: Static IP=192.168.... Gateway=192.168.... Subnet=255.255.255.0 DNS1=192.168.... DNS2=0.0.0.0
[10:35:41][V][wifi:365]: Hidden: NO
[10:35:44][ 9700][V][WiFiGeneric.cpp:353] _arduino_event_cb(): STA Connected: SSID: _ssid_, BSSID: xxx, Channel: 1, Auth: WPA2_PSK
[10:35:44][ 9702][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 4 - STA_CONNECTED
[10:35:44][ 9706][V][WiFiGeneric.cpp:367] _arduino_event_cb(): STA Got New IP:192.168....
[10:35:44][V][wifi_esp32:553][arduino_events]: Event: Connected ssid='_ssid_' bssid=xxx[redacted] channel=1, authmode=WPA2 PSK
[10:35:44][ 9739][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 7 - STA_GOT_IP
[10:35:44][ 9739][D][WiFiGeneric.cpp:991] _eventCallback(): STA IP: 192.168...., MASK: 255.255.255.0, GW: 192.168....
[10:35:44][V][wifi_esp32:607][arduino_events]: Event: Got IP static_ip=192.168.... gateway=192.168....
[10:35:44][I][wifi:617]: WiFi Connected!
[10:35:44][C][wifi:428]: Local MAC: ...
[10:35:44][C][wifi:433]: SSID: '_ssid_'[redacted]
[10:35:44][C][wifi:436]: IP Address: 192.168....
[10:35:44][C][wifi:440]: BSSID: xxx[redacted]
[10:35:44][C][wifi:441]: Hostname: 'led-attic'
[10:35:44][C][wifi:443]: Signal strength: -52 dB ▂▄▆█
[10:35:44][V][wifi:445]: Priority: 2.0
[10:35:44][C][wifi:447]: Channel: 1
[10:35:44][C][wifi:448]: Subnet: 255.255.255.0
[10:35:44][C][wifi:449]: Gateway: 192.168....
[10:35:44][C][wifi:450]: DNS1: 192.168....
[10:35:44][C][wifi:451]: DNS2: 0.0.0.0
[10:35:44][D][wifi:626]: Disabling AP...
In the config I have:
wifi:
# fast connect not compatible with "networks"
# fast_connect: True
manual_ip:
static_ip: 192.168....
gateway: 192.168....
dns1: 192.168....
networks:
bssid: xxx
priority: 2
bssid: yyy
priority: 1
It connects to the first network I specify, but after doing a full scan.
Now I’ll use a normal configuration, with only SSID and password, which allows me to use fast_connect, letting ESPhome pick the network. It does what I expect and it pops up in HA within 3 seconds from boot!
However, the fast_connect does not guarantee the best network. Unfortunately ESPhome is not optimal in this regard:
opened 01:22PM - 26 Mar 25 UTC
**Describe the problem you have/What new integration you would like**
- delayed… scanning/reconnection:
fast_connect uses the first network it finds, but not the strongest.
As far as I know, there is no way to later perform a scan and reconnect to the actual strongest network.
Introducing this optional feature would allow to get the best of the two worlds: quick connect, and shortly after, strongest signal.
- storage of best BSSID:
An additional optional feature could be to improve even further, by saving to flash the strongest BSSID, so that at the next boot fast_connect would not even need to scan to find the "first network", but it would directly attempt connecting to the previous strongest BSSID, falling back to the current fast_connect approach only if the BSSID saved doesn't work.
This would also reduce power consumption for the wifi connection step.
Of course, if the previous strongest BSSID does not exist/is not reachable anymore, the "improved" fast_connect would fall back to the current fast_connect, which scans and picks the first BSSID it finds
The two options are independent.
**Please describe your use case for this integration and alternatives you've tried:**
I have a smart light which needs to be reachable as soon as possible to receive commands from HA. I used fast_connect to get a connection as fast as possible, but directly attempting connection to the previous BSSID would speed up things even more.
Since my light is placed in a place where it could get signal from two different APs, a background scan later to ensure it's using the best AP would be desirable.
I am aware of other people having troubles with ESP not finding the best network:
https://community.home-assistant.io/t/esphome-does-not-connect-to-the-strongest-wifi-ap/569560
Also, I am aware of the option to specify multiple networks "networks:", but my proposal would automate the process and for many user bring easier configuration with just as good (or better) results.
**Additional context**
Bakke wrote about similar technique in his article with the purpose of reducing power consumption:
https://www.bakke.online/index.php/2017/06/24/esp8266-wifi-power-reduction-avoiding-network-scan/
Can someone please upvote the feature request, which would allow a fast connection and also the choice of the best network?
Hellis81
(Hellis81)
May 21, 2025, 9:08am
13
Just to note it.
You redacted the wrong thing in your post.
Your 192.168 IP is the local IP in your house.
I also have a 192 IP. Most do.
However the SSID is what most people redact since that can be reverse searched to get the location.
But it requires someone who actually cares to do it.
