I run a HA setup that is on a standalone machine (HAOS) with a Aeotec 700 series USB ZWave dongle. My system restarts daily in the early hours of the morning.
There are a few devices that will sometimes not properly “re-connect” to the mesh network and I wrote a script in HA that will ping these specific devices to revive them. I see approximately 1-2 devices per week have an issue and HA is almost always able to re-establish the communications and carry on.
Today, however, I had a large group of devices lose connectivity and there was no way I could recover a handful of them short of removing power and re-establishing power to them. I have three Honeywell thermostats - two of them need to be power cycled while the third came back on its own.
I also was unable to revive a few different in-wall switched / dimmers until I power cycled a plug-in switch and manually brought it back on line.
Any suggestions on how I might handle something like this in a more automated manner going forward? Maintaining smooth operations and communications is quite important, especially for the thermostats, to ensure proper heating and interior temp monitoring when we are away during the cold months.
I am not very technical and I am not at all sure that my experience helps. However a few months ago I had a similar issue. When I changed HA on RPi4 to a mini pc, all Zwave issues disappeared. It was a matter of the RPI having reached its capacity level.
My system “should” be operating well within its capabilities / limitations as A) I’m running on an Intel NUC8 with 16GB RAM and only 6% of the total disk space actually being used and B) this is not the norm to lose this many devices, lose many of these specific devices, or have to power cycle devices to get them back into a working state.
This happened to me yesterday after updating Zwave JS UI. Three of my GE/Jasco wall switches and three shades needed to have the power cut to restore use. I am 95% sure this was a result to that update as I have never had this problem before.
The wall switches wouldn’t even work mechanically at the switch itself. I’m not sure how an update can cause this, but it apparently did.
Questions:
Did you update the zwave integration recently?
Have you restarted since reconnecting your devices, and if so are they OK after the restart?
Yes, I have updated both Core and ZWave JS UI in the last couple of days. After the updates, I did notice a little lag with a couple of devices but didn’t experience the larger dropout until overnight after the system rebooted itself.
I lost a battery-powered moisture sensor, two GE/Jasco plug-in switched outlets, three Honeywell ZW1000 thermostats, an Aeotec plug-in switched outlet, a GE/Jasco in-wall switch, and a couple of other devices that I forget at this point. Everything worked properly via manual mode, the thermostats showed “Connect Lost”, and two of the thermostats needed power cycles to get back on the network (as did the Aeotec plug). Everything else came back more easily.
Daily restarts ensure that all patches are applied, any config updates are applied, and the system is just generally healthy overall. My environment is almost 100% ZWave and the mesh sometimes develops some lag due to communications being interrupted or sometimes just a chatty device. A restart will clear all of this chatter and re-initialize the mesh to expose any lingering issues that might need attention. This also prevents situations where the system gets rebooted right before I take a week’s vacation and nothing is working correctly while I’m not home to troubleshoot and fix.
I restarted it right after I discovered the mass drop-off, no change from a restart. I manually brought everything back into the fold, the system restarted itself overnight as usual, no issues this morning (that includes the automation I wrote to re-connect specific devices that sometimes don’t come back online cleanly).
Since implementing the early AM restart every day, I’ve had very few “surprises” with devices that don’t respond at all, drop off of the network, or take too long to respond. The system just seems to work much more efficiently all of the time.
I’m just curious - how many z-wave devices? how many of them are mains powered and how many of them are on battery?
Also is there only one version of Aeotec 700 series USB dongle? I thought they have multiple but can’t recall.
I have 77 devices, including the Aeotec controller. The following at the battery-powered devices I have:
Four Hank 4-button scene controllers
Aeotec 4-button touch pad scene controller
Door tilt sensor (garage door)
Three door/window sensors
Moisture / water sensor (have a second one of these to add still)
So, ten battery devices in total currently deployed. Three Honeywell ZW1000 thermostats powered off of the HVAC system. The controller stick is USB-powered off of the NUC8 and the remaining are all mains-powered (in-wall switches that are hardwired and plug-in switch plugs).
I’m not aware of multiple 700 series controller sticks, but I suppose that it’s possible since it’s been around “long enough” to have possibly gotten some modifications to it.
They do have multiple controller sticks with one being in the 500 series camp and another being 800 series.
