Hello everyone,
I use the Climate Card to control my heating. all data comes via MQTT (BSB-LAN).
The data for my Climate Card comes via a YAML file called climates.yaml.
This file looks like this:
- name: "Fußbodenheizung EG HK1"
unique_id: sb_lan_climate_fbh
availability_topic: "BSB/status"
payload_on: 1
payload_off: 0
modes:
- auto
- heat
- cool
- "off"
mode_state_topic: "BSB/1000!1"
mode_state_template: >-
{% set values = { '0 - Schutzbetrieb':'off', '1 - Automatik':'auto', '2 - Reduziert':'cool', '3 - Komfort':'heat'} %}
{{ values[value] if value in values.keys() else 'off' }}
mode_command_topic: "BSB"
mode_command_template: >-
{% set values = { 'off':'S1000=0!1', 'auto':'S1000=1!1', 'cool':'S1000=2!1', 'heat':'S1000=3!1'} %}
{{ values[value] if value in values.keys() else '0' }}
current_temperature_topic: "BSB/8740"
current_temperature_template: >-
{% if value == '---' %}
{{ 'None' }}
{% else %}
{{ value }}
{% endif %}
min_temp: 5
max_temp: 30
temp_step: 0.1
temperature_state_topic: "BSB/710!1"
temperature_command_topic: "BSB"
temperature_command_template: "{{'S1010!1='+ (value| string)}}"
device:
identifiers: ["00000002"],
model: "SOB22C",
manufacturer: "Brötje",
The whole thing actually works great, but I have a different mqtt message for each mode set (heat, cool, etc.).
It is currently reading the value for display in the climate card from temperature_state_topic: “BSB/710!1”. However, this is only true if the thermostat is set to heat. For the cool setting he would have to query the topic “BSB/712!1” and for off the topic “BSB/714!1”.
My idea was to set the point like this:
temperature_state_topic: "BSB"
temperature_state_template: >-
{% if state_attr('climate.brennwertheizung_fussbodenheizung_eg_hk1', 'hvacmode.heat') %}
{{ '710!1' }}
{% elif state_attr('climate.brennwertheizung_fussbodenheizung_eg_hk1', 'hvacmode.cool') %}
{{ '712!1' }}
{% elif state_attr('climate.brennwertheizung_fussbodenheizung_eg_hk1', 'hvacmode.off') %}
{{ '714!1' }}
{% endif %}
So that, depending on which Hvac mode is currently active, the appropriate temperature is displayed, completely like this:
unique_id: bsb_lan_climate_fbh
payload_on: 1
payload_off: 0
modes:
- auto
- heat
- cool
- "off"
mode_state_topic: "BSB/700!1"
{% set values = { 'off':'S700=0!1', 'auto':'S700=1!1', 'cool':'S700=2!1', 'heat':'S700=3!1'} %}
current_temperature_topic: "BSB/716!1"
{{ 'None' }}
{% else %}
{{ value }}
{% endif %}
min_temp: 5
max_temp: 30
temp_step: 0.1
{{ '710!1' }}
{{ '712!1' }}
{{ '714!1' }}
{% endif %}
temperature_command_template: "{{'S710!1='+ (value| string)}}"
device:
model: "SOB22C",
Unfortunately the whole thing doesn’t work that way, I’m also an absolute noob when it comes to creating individual yaml files, for me it’s more like copy & paste, I hope someone can still help me and point me in the right direction.
best regards
Pierre
