I just started with ESPhome and arduino’s in general. I want to use an ESP01 to flash a light and to read whether a switch is on/off. I have connected the esp to my arduino and I am able to turn on/off a led. I noticed that this only works when using GPIO1. I also noticed that when I turn on the (external Led), the onboard Led turns off and vice versa.
Then I connected a push button to my arduino. When it’s pressed it sets the digital pin connected to the ESP to HIGH. I want to see in my dashboard when this button is pressed. Therefor I added this “sensor / switch” to my dashboard, but it always shows me that it is switched off.
I used the code below to configure my esp8266. What am I doing wrong?
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: xxx"
password: "xxx!"
use_address: "192.168.1.xx"
manual_ip:
static_ip: 192.168.1.xx
gateway: 192.168.1.1
subnet: 255.255.255.0
dns1: 192.168.1.1
ap:
ssid: "Nodetest Fallback Hotspot"
password: "MmOYpJXEjU0Z"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "xx
ota:
password: "xx"
switch:
- platform: gpio
name: "Blauw Lampje Yori"
pin: 1
binary_sensor:
- platform: gpio
name: "Alarm Knop Yori"
pin: 2
