How to read or write into a Helper out of an esphome yaml-script?
In the following code i would like to write into a helper, but i am not able to do it … can someone give me an example?
Thanks for your help
prevent deep sleep
binary_sensor:
  • platform: homeassistant
    name: Prevent Deep Sleep
    entity_id: input_boolean.do_sleep
script:
  • id: consider_deep_sleep
    mode: queued
    then:
    • delay: 60s
    • if:
      condition:
      binary_sensor.is_on: start_deep_sleep
      then:
      - logger.log: ‘Start deep_sleep …’
!!! Here i want to write into a helper ‘deepsleep_status’, but i am not able to do it !!!
        - deep_sleep.enter: deep_sleep_bewaesserung
      else:
        - deep_sleep.prevent: deep_sleep_bewaesserung
        - logger.log: 'Skipping sleep, per prevent_deep_sleep'
  - script.execute: consider_deep_sleep
deep_sleep:
run_duration: 1min
sleep_duration: 3min
Post your yaml properly please. See How to help us help you - or How to ask a good question
But I think you’ll find it is something like this
  - homeassistant.service:
      service: input_text.set_value
        value: "Entered Deep Sleep"
        entity_id: input_text.sleepy
Thanks for your support.
… you are right - i have to get more expirience to send better (clean) information. I know - i have to learn how to do in the forum. Thanks for your hint!
Werner
