In an other threat I did ask the next question, but I recognized it was the wrong chapter to ask:
I’m working in node RED:
My zwave with a dongle straight to HA was giving bad reliability, so I decided to order a VeraEdge as zwave hub.
I installed it and for test I paired a Neo coolcam wallplug.
It is vissible into HA and can control it by nodeRED so the basics are working.
If I connect a neo coolcam plug straight to HA I do have a lot of entities to act with. Also power for example.
From Vera devices I only see one entity switch on and off the plug, no sensors.
I like to have the possibility to switch on power usage.
At the tile on the overview I do see the power changing. How to check on this in nodeRED without having the sensor entitie “power usage”?
I learned that it is a “state”, but how to read the state in this case from:
switch.neo_10_kerst_raam_4
the state is named:
current_power_w
I tried: states.switch.neo_10_kerst_raam_4.attributes.current_power_w in a current state node, but didn’t succeed, giving an error: entity could not be found in cache
