How to read switch status from Shelly Plus 1?
I am using one of the new shelly plus 1 devices to remote control an appliance. The device has a SW input to detect if a switch is active. This can be either used to directly control the shelly device or it can be set as detached and used as a separate sensor. In that case, how would I access the state of SW from HA? The standard integration does not provide any sensor for the switch state.
Thanks for any ideas.
Either way, you should see a binary sensor named “(Device Name) Input” that shows the current state of the physical switch. I think in my most recent addition of a Shelly Plus 1PM I had to manually enable this sensor, i.e. by default it was hidden behind a “+1 entity not shown” link in the “Sensors” section of the device configuration.
Unfortunately it’s not there, I run the Shelly Plus 1 without the PM. Other sensors do show (also binary like cloud), but not the SW input of my Shelly plus 1.
Is there any update on this? I would like to read the state from a Shelly Plus 1 using the native Home Assistant Shelly integration. However, no sensor is created when adding a Shelly Plus 1.
You have to enable it here.
I’m facing the same issue. I don’t have a sensor and I can’t see an option to enable one. I do have a hidden Event but that’s not giving me something as straightforward as a binary_sensor
Update: Found the solution in another thread. Change the Input/output settings to Switch.
In case this helps someone else the above black screens are what you get when you use the HA screen, Intergrations, Shelly. I then enabled the on/ off sensor. At first it says it was Disabled but at a lower level I found how to Enable it. Not very intuitive.
