I ordered a couple of power meter-capable plugs which actually work via Deconz. I can turn them on and off. Via the Deconz integration I can even view the Electrical Measurements via the Cluster info tab. How can I read those measurements in Home Assistant? If it means that I need to use some API, that is fine too, but I can’t find any documentation on this.
Thanks in advance!
