How to reboot hassio?
Hi, i’ve noticed that my deconz appears to completely crash after a couple of days operation. a complete reboot (well, at that point, yanking the power cable) helps to restore functionality.
so i attempted to create a simple automation so i don’t have to manually restart my raspberry pi when it happens:
shell_command:
  reboot_host: ha host reboot
with an automation like:
- alias: Reboot HASS
  - platform: time
    at: "19:00:00"
  - service: shell_command.reboot_host
It triggers fine, however, the follow error shows up in the logs:
Logger: homeassistant.components.shell_command
Source: /usr/src/homeassistant/homeassistant/components/shell_command/__init__.py:111
Integration: Shell Command (documentation, issues)
First occurred: 19:00:00 (1 occurrences)
Last logged: 19:00:00
Error running command: `ha host reboot`, return code: 127
NoneType: None
what is the correct command i should use to reboot the entire raspberry pi?
cheers!
I would suggest using the service call built for this: hassio.host_reboot
In an automation action, it would look like this:
  - service: hassio.host_reboot
    data: {}
of course! much simpler :slight_smile: thanks @Silicon_Avatar!
