with a lot of patience, I was helped by @TheFes in editing my sun-boiler automation. I wanted a notification with the period the boiler was heated (and thus optimize the duration between runs…)
this is what I have now, and it works acceptably well. It does however have an ‘issue’.
The first switch binary sensor turn_on action takes a while to happen, after the automation has been successfully triggered. It thus makes the final message in the notification report the incorrect time. It state the full time of the automation, and not exactly the time the switch binary has been on for:
- alias: Zonneboiler schakelen
platform: time
at: '05:00:00'
condition:
{% set delay = states('input_number.zonneboiler_periode')|int(default=23) %}
{{now() - this.attributes.last_triggered > timedelta(hours=delay) if
this.attributes.last_triggered is not none else true}}
- condition: >
{{states('binary_sensor.opentherm_dhw_state') not in ['unavailable','unknown']}}
- service: switch.turn_on
entity_id: switch.opentherm_dhw_comfort_mode
- wait_template: >
{{is_state('binary_sensor.opentherm_dhw_state','on')}}
- wait_template: >
{{is_state('binary_sensor.opentherm_dhw_state','off')}}
- service: switch.turn_off
# this next wait_template is required to prevent the message from templating the 'former' trigger, as the switch has not been turned_off immediately
- wait_template: >
{{is_state('switch.opentherm_dhw_comfort_mode','off')}}
- condition: state
entity_id: input_boolean.notify_appliance
state: 'on'
- service: notify.mobile_app_marijn
title: >
{% set time = now().strftime('%X') %}
{{time}}: Zonneboiler schakelaar
message: >
Zonneboiler is weer opgewarmd, en uitgeschakeld na
{{(states.switch.opentherm_dhw_comfort_mode.last_changed -
state_attr(this.entity_id,'last_triggered')).seconds
|timestamp_custom('%M:%S',False)}} minuten
Alternatief:
{{(now() - trigger.now).seconds|timestamp_custom('%M:%S',False)}}
I have been wondering about a timer to set. turn_on switch binary, turn_on timer, wait for the switch binary to be turned_off, and then turn_off timer.
Next, template the time the timer was on, and report that in the message… But how?
Or, maybe even more verbosely, use an input_datetime to record the turn_on, and another for turn off, and then template the time difference…? Would be really nice if we could do this, (and we probably can, I just couldn’t figure out how).
- service: input_datetime.set_datetime
entity_id: input_datetime.zonneboiler_aan
timestamp: >
{{ now().timestamp()}}
# or use
# datetime: "{{now().strftime('%Y-%m-%d %H:%M:%S')}}"
- wait_template: >
- wait_template: >
entity_id: input_datetime.zonneboiler_uit
timestamp: >
{{now().timestamp()}}
on for
{{(as_timestamp(states('input_datetime.zonneboiler_uit'))
as_timestamp(states('input_datetime.zonneboiler_aan')))
so, please have a look if you can help me find a way to do so.
thx!
