When restarting after out of disk space failure, it was displaying messages about fsck:
(This is Ova VM version)
It looks like embedded Docker container issue?
found out in form about using login here
And then it wouldn’t boot and opened into ha shell. In that shell there’s no fsck and I just want to ask what is the safe boot procedure to check the disk.
Eventually, after two more reboot attempts it started normally by itself, but I am concerned that corrupt blocks are still there,.
The Haos guide didn’t help me.
- If I get into “emergency” shell situation again, how to I fsck from here?
- Now It booted normally, what do I do to run fsck, and/or anything else need to do for maintenance?
Thank you.
