How to recreate device in MQTT integration after deletion? (Terncy Awareness Switch)
I have successfully added Terncy Awareness Switch to HA through zigbee2mqtt and the device has been auto created in the MQTT integration. However, I mistakenly deleted the device in the MQTT integration. How can I recreate the device?
I have tried to add the switch again through zigbee2mqtt but I still can not find the device in the MQTT integration.
Please help!
Hello , i still have the same issue,
my issue was that i had a not working MQTT Integration, but my broker was working fine, so payloads are passing throu.
Than i have deleted the whole MQTT Integration, but now the devices are not more discoverable. so old known devices or entitys can not be discovered again.
also Strange was that i have installed the RF Gateway last year with version 0.9.8. Now im using 1.1.1 with new board.But still HA MQTT is showing me only the old Naming
Has this something to do with the Unique_id issue?
This bug should be fixed in future, maybe if a integration was erased ask what about the devices that were connected , also delete?
Otherwise we have some old configurations that mix the system up
attached…
Hello! What did you do to fix this? I’m having the same issue. Ugh!
