Hello everybody.
I have configured all switch from my remote on HA. I have add too my yeelight light but i don’t know to simply control my light with my remote. I don’t found documentation or topic here for this basic task soo thanks for your help.
Hello everybody.
You dont mention what type of remote control. Lets assume it is a lirc Infra-red:
automation:
- id: poutre_toggle
alias: 'Poutre Toggle'
platform: event
event_type: ir_command_received
event_data:
button_name: A1 # make sure this is your button name
service: light.toggle
entity_id: light.poutre # make sure this is the entity_id of your light
Tanks for your attention.
switch come from rfxtrx remote like :
switch:
platform: rfxtrx
automatic_add: true
devices:
0b11000001313efeXXXXXfXX:
Ok, try this:
automation:
- id: poutre_toggle
platform: event
event_type: button_pressed
event_data: {"entity_id": "switch.t1a1"}
You will also have to change your switch config to:
switch:
platform: rfxtrx
automatic_add: true
devices:
fire_event: true # <------ add this
after 2 days of adventures, i’ve progress on my home assistant code understanding.
My light turn on correctly when i manually activate my automation but my remote controlleur has one button for on and one button for off. she is correctly add to hasio like rfxtrx switch because hasio update correctly this switch on his panel but my automation triggr don’t work.
See my automation code
#on automation
- id: '1566199046443'
alias: 'poutreOn'
- platform: event
service: light.turn_on
for your comprehension this is my remote
What is the entity id of this switch?
Also what is the entity id of the switch you want to use to turn off the light?
That does not show the entity ids of the switches.
Open up your lovelace card and copy the relevant on and off button entities. e.g:
Paste them here. Don’t screen shot them.
You still have not said which is the button that you want to use to turn off the light.
i want turn off and turn off my light at the end but for the moment, the switch trigger don’t work for anything. Just turn on fort first step will make me happy
Try this then:
alias: 'poutreOn'
platform: state
entity_id: switch.t1a1
to: 'on'
ha ha ha ! it’s alive !!!
light go to on
thanks, first step managed
my automation for on off (probably coded like a bear but work)
alias: 'poutreOn'
platform: state
to: 'on'
brightness: 255 #light power
kelvin: 4400 #light color
- id: '1566199046444'
alias: 'poutreOff'
platform: state
to: 'off'
service: light.turn_off
