How to remote control TCP BAXI heat pump with modbus RS 485
Hi everyone, I would like to share with you the solution I used to connect the Baxi heat pump (Auriga 16M-A) remotely to HA, but I guess it works with all of them. To do this I only purchased a conversion device between the Modbus RS 485 protocol and the TCP / IP.
The remote control is of the type you see in the image, that it is used also for other heat pump :
Cattura2
I used the Elfin-EW11A device. The wiring part by the Baxi control module or similar takes place via connectors H1 and H2 on B and A respectively of the converter.
After this, access the converter configuration to set the IP address of the converter and the port to be used for RS 485 communication. In my case the address is 192.168.1.12 and the port is 8899. Once this is done there is nothing else to do on the converter. In the configuration.yaml file we insert the following code to open the connection
# Configurazione Modbus RTU-to-TCP
modbus:
  - name: "BAXI_modbus"
    type: tcp
    host: 192.168.1.12  # Indirizzo IP del gateway RTU-to-TCP
    port: 8899           # Porta TCP del gateway
    sensors: !include sensorBAXI.yaml
and now let’s create the sensorBAXI.yaml file:
      - name: "PLC_Status"
        slave: 1                # ID del dispositivo RTU
        address: 0              # Indirizzo del registro (40001 -> 0 in Home Assistant)
        input_type: holding     # Tipo di registro (holding per 4xxxx)
        data_type: uint16       # Tipo di dato (16 bit unsigned integer)
        scan_interval: 3    # Intervallo di scansione (in secondi)
      - name: "Valore Temperatura Termosifoni" #T1s
        address: 2          # Indirizzo del registro (40003 -> 2 in Home Assistant)
        data_type: int16   # Tipo di dato (16 bit unsigned integer)
        unit_of_measurement: "°C"  # Unitá di misura (Temperatura in gradi Celsius)
      - name: "Valore Temperatura Aria" #Ts
        address: 3          # Indirizzo del registro (40004 -> 3 in Home Assistant)
        scale: 0.01
      - name: "Valore Temperatura ACS Target" #T5s
        address: 4          # Indirizzo del registro (40005 -> 4 in Home Assistant)
      - name: "Valore Temperatura Ambiente Esterno" #T4
        address: 107          # Indirizzo del registro (40108 -> 107 in Home Assistant)
      - name: "Valore Temperatura Acqua Uscita" #T1B
        address: 111          # Indirizzo del registro (40112 -> 111 in Home Assistant)
      - name: "Valore Temperatura Ambiente" #Ta
        address: 114          # Indirizzo del registro (41115 -> 114 in Home Assistant)
      - name: "Valore Temperatura Bollitore ACS" #T5
        address: 115          # Indirizzo del registro (41116 -> 115 in Home Assistant)
      - name: "Valore Alta Pressione" #P1
        address: 116          # Indirizzo del registro (41117 -> 116 in Home Assistant)
        unit_of_measurement: "kPa"  # Unitá di misura (Temperatura in gradi Celsius)
      - name: "Valore Bassa Pressione" #P2
        address: 117          # Indirizzo del registro (41118 -> 117 in Home Assistant)
      - name: "Valore Corrente"
        address: 118          # Indirizzo del registro (41119 -> 118 in Home Assistant)
        unit_of_measurement: "A"  # Unitá di misura
      - name: "Valore Tensione"
        address: 119          # Indirizzo del registro (41120 -> 119 in Home Assistant)
        unit_of_measurement: "V"  # Unitá di misura
      - name: "Limite Superiore di temperatura riscaldamento"
        address: 203          # Indirizzo del registro (4204 -> 203 in Home Assistant)
      - name: "Limite Inferiore di temperatura riscaldamento"
        address: 204          # Indirizzo del registro (4205 -> 204 in Home Assistant)
      - name: "Limite Superiore di temperatura impostazione"
        address: 205          # Indirizzo del registro (4206 -> 205 in Home Assistant)
      - name: "Limite Inferiore di temperatura impostazione"
        address: 206          # Indirizzo del registro (4207 -> 206 in Home Assistant)
      - name: "Limite Superiore di temperatura dell'acqua riscaldamento"
        address: 207          # Indirizzo del registro (4208 -> 207 in Home Assistant)
      - name: "Limite Inferiore di temperatura dell'acqua riscaldamento"
        address: 208          # Indirizzo del registro (4209 -> 208 in Home Assistant)
      - name: "Limite Potenza Ingresso"
        address: 269          # Indirizzo del registro (4270 -> 269 in Home Assistant)
Now, you have all the heat pump parameters available for viewing. If you want to modify the parameters you must insert a script to write the various bits or states at the right point as in the example below
modifica_bit_1:
  alias: "Modifica Bit 1 PLC Status"
  sequence:
    - variables:
        current_value: "{{ states('sensor.PLC_Status') | int }}"
        new_value: "{{ (current_value | int) | bitwise_xor(2) }}"
    - service: modbus.write_register
        hub: BAXI_modbus
        unit: 1
        address: 0
        value: "{{ new_value }}"
modifica_bit_2:
  alias: "Modifica Bit 2 PLC Status"
  sequence:
    - variables:
        new_value: "{{ (current_value | int) | bitwise_xor(4) }}"
        hub: BAXI_modbus
        unit: 1
        address: 0
In fact, the first script allows you to modify the bit that manages the switching on of heating zone 1, the second script modifies the bit that manages the switching on of the domestic hot water.
By doing this I configured the heat pump management page on HA, as I am sharing with you, with the various thermostats for adjustments, switch-ons and powers.
Let me know if you need anything else so I can help you, regards.
This is my HA dashboard to control Heat Pump Baxi 16A-M
Ciao, I have a Baxi CSI Alya heat pump that is sold as a WiFi version, but the app is a shame, unusable and unconnectable with any IoT platform. Your post is exactly what I was about to start to do, thank you a lot for sharing your work!! I’ll keep updated if it is working also with this model
I installed the Elfin in parallel with my heat pump keyboard controller, but unfortunately I am not able to retrieve any good data. I see that some data are received from the elfin status page, but something is wrong reading modbus communication. Could you please share your elfin serial port settings? I used also modbus scanner, but i get back only timeouts and errors…Thanks
HI @Amberfin_Agent, where do you get the addresses and its descriptions? I want to Turn off the unit.
@cudiz27 just found the info: Port: RS-485; the wired controller XYE is the communication port for connection to the hydraulic module. H1 and H2 are the Modbus communication ports.
Communication address: consistent with the DIP switch address of the hydraulic module.
Baud rate: 9600
Number of data bits: eight
Parity: none
Stop bit: 1 bit
Communication protocol: Modbus RTU (Modbus ASCII is not supported)
dove hai preso l’alimentazione? hai usato i morsetti A e B del control panel?
Ciao @cudiz27 have you fixed the problem? I’m interested because in the same conditions… Thanks
Unfortunately I didn’t manage to make it work in any way :slightly_frowning_face:
Hi!
I’m deploying a similar setup, but sadly the updating of the control bits for the turn on and off of the ACS and the control bits in the same area isn’t working, is there any chance you can help me with it?
I’ve followed your setup and modified the changing part by using a template switch with the following:
- switch:
      - name: "Auriga ON/OFF ACS"
        unique_id: auriga_on_off_acs_bitwise
        state: >
          {{ (states('sensor.plc_status') | int(0) | bitwise_and(4)) > 0 }}
        turn_on:
          action: modbus.write_register
            hub: "PdC Abitazione Baxi Auriga"
            slave: 1
            address: 0
            value: >
              {{ states('sensor.plc_status') | int(0) | bitwise_or(4) }}
        turn_off:
            slave: 1
            address: 0
            value: >
              {{ states('sensor.plc_status') | int(0) | bitwise_and(65531) }}
