I have previously created 2 helpers to calculate consumed power but later on the device is removed but I did not remove the 2 helpers before removing the device. Now the 2 hepers does not have a entity_id and I can’t find anywhere to remove them. Can anyone advise how I can remove these 2 helpers?
No it’s not there. I remember it was there when the 2 helpers were working.
I have created another “test” helper using the Riemann sum integral sensor, however the Riemann Sum / Integration card is still not under “Settings → Devices & Services → Integrations”
Hmm. Ok. I don’t use the UI to set up Riemann Sum helpers I use YAML, buy it looks to me like you found an issue. Could you please open a new issue here:
Yeah ok. If it was YAML you could have edited/deleted the YAML.
There is a method for fixing this by editing the files in /config/.storage but unless you know what you are doing it has the potential to make things a lot worse. These files are not supposed to be user editable.
I can raise the issue but happy to be adventurous as well to get rid of them and I can make backup of the files before I do that. In fact I did try to remove 2 entries in core_entity_registry but that doesn’t change anything… and then I installed Spook but it didn’t detect the issue as well so I’m asking for help here.
I have the same problem with several helpers (groups of lights), they don’t receive an ID when created with UI, they don’t appear as entities and they can’t be used or deleted.
I have the same problem. The helpers are named “unnamed statistics”. Reloading the page, rebooting etc. didn’t solve the problem. I have even created a new helper and made sure the unique id was entered. It again ended up in “unnamed statistics”, not having a unique id. If someone can tell the SQL queries to fix it, I’m ready to take the risk.
Did anyone create an issue on this? I ran into the same problem right now. What is extra annoying is that although it no longer shows the previous entity name, that name is still reserved when I try to create a new helper with the correct name.
