So I had a problem with one of my devices and had to sent it back for a replacement. I didn’t think to unpair it before sending it so I no longer have it. How do I remove it? it wasn’t a failed node so I can’t use the Replace Failed Node functionality, unfortunately.
you should have the node showing up as ‘buffer’ something? from memory…? (i cant quite remember, something other than ‘Node:# Complete’ anyway) Then select it and hit “remove failed node”. Pretty sure you will need to restart HA for it to take effect.
I’ve now managed to get this issue, so that my logs are showing:
Unknown Node 19 Temperature (node_id: 19) not ready after 30 seconds, continuing anyway
But I dont understand WHERE the node should show up and where to delete? I can find it as “unknown” i zwave device mgmt, but no “remove failed node” anywhere?
I also have an unknown Z-Wave mode that cannot be removed because it says “is_failed”: false.
The steps described here are confusing and I cannot reproduce them:
Go to the States menu under Developer tools in the Home Assistant frontend
Click on the name of the zwave. entity you want to remove
Make note of the entity’s “node_id” value as you will need to re-add the “node_id” attribute and value in step 4.
At the top, edit the JSON attributes to replace false with true for "is_failed": false, so that it reads "is_failed": true. Also add the “node_id” value to the number listed in the entity’s attribute.
Click Set State
Go to the Z-Wave control panel in the Home Assistant frontend
Click the Remove Failed Node button in the Z-Wave Node Management card
The device will now be removed, but that won’t show until you restart Home Assistant
I’m on a quest for this very same issue.
I already tried this trick of Removing Failed Node, but after a HASSIO reboot it is still there in “CacheLoad” state.
When I try to use the Remove Failed Node command I get the following entry on the zwave log:
2020-12-29 21:58:18.930 Warning, contrlr, WARNING: Received reply to FUNC_ID_ZW_REMOVE_FAILED_NODE_ID - Node not found
So I suspect that the device is no longer associated with the zwave gateway, but somehow it is still associated somewhere in HASSIO.
Hi all, Zwave has changed a lot since I originally made this post and I don’t recall what state it was in. It was likely during the time of the original Home Assistant Zwave integration, not Zwave JS.
To remove a failed node today, you’ll need the Zwave JS UI to do it. If you’re using HAOS it’s pretty simple, use the Zwave JS UI add-on, rather than the regular Zwave JS add on. The UI add on has Zwave JS -and- the UI component.
So once you have Zwave JS UI, navigate to the UI and login, find your node that you no longer have and expand it. Open the advanced options, then select removed failed node. Zwave JS will ping your device and if it is not found after a few seconds the device will be removed. HA should reflect that the device is gone as well.
Please note I don’t have HA server up right now, I’m in the process of getting it running again so I recalled the above steps by memory. Apologies if any part is incorrect.
