How to remove Node Red node from palette
I have a conf node that came up missing and it stopped all my flows from running. Can anyone tell me how to delete nodes from the palette?
You can’t. You can uninstall the whole palette that contains that node and the node will be removed.
I could not remove the palette because the node was “in use” even though it wasn’t. The only thing that ended up working was to uninstall Node Red entirely then re-install. That palette is not “supported” in the new version so was apparently automatically removed during the install. I updated to a newer palette and added the new working nodes to my flows. All good now, but I don’t think it’s good practice to halt all flows for a node that isn’t even in them.
