Device Details to help others
TS0601 by _TZE200_dwcarsat
Quirk: zhaquirks.tuya.air.ts0601_air_quality.TuyaCO2SensorGPP
I have these zigbee multi sensor devices that report temp, humidity CO2 etc. I like the the fact that they are plugged in and not battery. anyway im getting these cluster warning
The common number in all of these is 0xef00
. So when i go to the clusters for this device its Clusters
TuyaCO2ManufCluster (Endpoint id: 1, Id: 0xef00, Type: in)
I just want to know if this can be removed or filtered from my logs to not show?
* [0x324C:1:0xef00] No 'handle_set_data_response' tuya handler found for set_data_response(data=TuyaCommand(status=0, tsn=1, dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x05\x00\x00\x00', *payload=5)))
* [0xE338:1:0xef00] No 'handle_set_data_response' tuya handler found for set_data_response(data=TuyaCommand(status=0, tsn=2, dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x04\x00\x00\x00', *payload=4)))
* [0x9F26:1:0xef00] No 'handle_set_data_response' tuya handler found for set_data_response(data=TuyaCommand(status=0, tsn=2, dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x05\x00\x00\x00', *payload=5)))
* [0x8618:1:0xef00] No 'handle_set_data_response' tuya handler found for set_data_response(data=TuyaCommand(status=0, tsn=5, dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x00\x00\x00\x00', *payload=0)))
* [0x324C:1:0xef00] No 'handle_set_data_response' tuya handler found for set_data_response(data=TuyaCommand(status=0, tsn=5, dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x04\x00\x00\x00', *payload=4)))
