I have Powercalc integration installed via HACS.
Now I removed the integration (in HACS) and deleted all dependent entities (from powercalc intagration).
All looks good. But trying to restart HA I get this error:
Log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/homeassistant/__init__.py:174
Integration: Home Assistant WebSocket API ([documentation](https://www.home-assistant.io/integrations/websocket_api), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+websocket_api%22))
First occurred: 16:58:16 (2 occurrences)
Last logged: 17:02:23
* [139630829482576] The system cannot restart because the configuration is not valid: Integration error: powercalc - Integration 'powercalc' not found.
* [139631013391776] The system cannot restart because the configuration is not valid: Integration error: powercalc - Integration 'powercalc' not found.
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service await hass.services.async_call( File "/usr/src/homeassistant/homeassistant/core.py", line 1787, in async_call task.result() File "/usr/src/homeassistant/homeassistant/core.py", line 1824, in _execute_service await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)( File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 756, in admin_handler await result File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 174, in async_handle_core_service raise HomeAssistantError( homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Integration error: powercalc - Integration 'powercalc' not found.
Logger: homeassistant.components.homeassistant
Source: components/homeassistant/__init__.py:163
Integration: Home Assistant Core Integration (documentation, issues)
I alredy restarted the Container to clear possible active Websocket connections. Still getting the error message on HA restart via HA settings/system.
Any ideas how to uninstall the integration completely?
Or how to find the still existing elements pointing on powercalc?
