When I go to the integrations page, I cannot remove those entities…
You can only remove 0 of the selected 1 entities. Entities can only be removed when the integration is no longer providing the entities. Sometimes you have to restart Home Assistant before you can remove the entities of a removed integration. Are you sure you want to remove the removable entities?
You have to remove the ESP integration for the device then restart before you can remove the entities. And if you do remove the Integration first the entities should be deleted too.
Thanks for the quick replies. I really appreciate the support. I thought I had this figured out, but then I broke it adding a second sensor. Maybe you can see where I am going wrong?
I ran the watchman service, but it doesn’t show anything:
[core-ssh config]$ cat watchman_report.txt
-== Watchman Report
-== Congratulations, all 2 services from your config are available!
= No entities found in configuration files!
Report created on 13 Aug 2022 17:14:37
Parsed 14 files in 0.05s., ignored @ files
Generated in: 0.00s. Validated in: 0.00s.
This is what my entities looks like where I can’t remove them:
Unfortunately not. Those entities stubbornly remain despite deleting the integration, the ESPhome config, and rebooting ad-infinitum. Remove option in the entity dialog is grayed out. In my case the entities were removed from an ESP config, but even if that device is removed from ESPhome AND integrations, the orphaned entities still appear and cannot be removed.
How i delete climate entity? I have “climate.autotalli” and i don’t know how to i delete it?
I remove generic thermostat code on configuration.yaml but i still find it
“climate.autotalli” entity on “device & services → entities”
How i delete it?
