How to remove the old zwave integration and fully switch to the ozw beta
This guide assumes you’ve completed the steps in How to test the OZW Beta without fully switching over
Now that you're testing the ozw beta out you've decided to fully switch over. Here's how to do that:
Disable the zwave integration:
configuration.yaml
# zwave:
#  usb_path: /dev/ttyACM0
#  device_config: !include zwave_device_config.yaml
AND
Remove the zwave integration from the integrations menu.
Click on the 3 dots, and select Delete
Both steps are important. Once these are removed you should no longer have a problem with the old integration fighting the OpenZWave beta integration.
