Hey,
I use the new configuraton and have the Problem, between some bigger and smaller parts is much space. How can ir remove it?
Hey,
I suppose you are experimenting with new Sections layout. Then the answer is no, it is by design, that rows have the same heigth as the biggest card in the row. Unfortunately using of Masonry layout within Sections dashboard is not possible. I have the same problem A bit pity as I had very high hopes for this layout, though as I use lots of dynamic cards (conditional visibility or dynamically changed heigth) it make the whole dashboard to look just bad…
You’ll need to use the card-mod custom component for the frontend to tweak things like this, unfortunately.
