I recently migrated to a SMLight SLZB-06 in ZHA. I flashed my old Sonoff ZB Dondle-P to a router using Sonoff Dongle Flasher. After flashing I plugged it in to configure it in ZHA as a router. The flash said successful, but it remained as a coordinator. Now I have two coordinators in ZHA. How do I get rid of the Sonoff ZB Dondle-P?
What device name is your Dongle-P showing in ZHA?
Normally, ZHA does not allow two coordinators. If you try to add another coordinator, ZHA will display the following message:
When you migrated coordinators, the SLZB-06 would have been assigned the ieee address of the original ZBDongle-P.
Did you change the ieee address of the ZBDongle-P when you flashed the router firmware?
If not, then ZHA is probably confused by two devices having the same address.
Ultimately you would need to remove the ZBDongle-P, change the ieee, and re-pair it.
Unfortunately, I’m not sure what the proper steps would be to remove it safely.
yes… The ieee was changed. The ZBDongle-P was flashed using Sonoff’s online flasher. When it gets flashed it wipes out all the stored config on the dongle, so ZHA in HA should look at it as a new device. The issue is that the flash didn’t work, although the Sonoff Online flash program said it was successful. So, when I added a device it was picked up and added to ZHA, but not as a router, rather a coordinator which I can’t find a way to get rid of.
It is impossible for a device to work with a “wiped” address.
I haven’t used the Sonoff online flasher, but I’m 99.9999999% sure the ieee was not changed unless you explicitly keyed in a new ieee address.
I’ve never seen any flashing software that routinely wipes or changes the device’s default ieee address.
Interesting… I restored a backup and have confirmed that the ieee is different than what it is now. I assume that the when the new device SLZB-06 was added it changed automatically as it is definitely different than the first ieee address
I’m in the same boat, only difference that I migrated ZHA from a ZBDongle-E to a SLZB-06M.
I flashed the sonoff dongle with a router firmware, I added as a new device to my zigbee network, but now shows up as a coordinator. The visualization shows all devices connected to this zigbee device and no option to remove it. I could not remove it with zha.remove developer action either.
Anyone got a solution for this?
Can you provide the topology diagram?
