I’ve found that I can rename the entities under the zwave domain, but any entities in other domains (light, switch, etc.) do not reflect the name that I supplied.
Is this the expected behavior? Can I rename sub entities from the zwave domain? What am I doing wrong?
That looks right. The entity is family_room_lights and it’s sub entities then append their relevant suffix, even if there’s only a single sub-entity (eg _switch).
Presumably for the same reason that switches have _switch appended. I’ve no idea what that is, I’ve simply observed that it’s the way OpenZWave does it.
Ah, I meant to say with OUT it appended but I actually went and doubled checked. That attribute does show the entity id with the appended value. I must have been looking at the zwave node when I found that before.
