How can I migrate my installation from a ConBee II to a Sonoff Zigbee 3.0 Stick?
I am using ZigBee2MQTT in case that matters.
They explain it in their FAQ, but as far as I know it’s not possible to migrate from a ConBee to anything else.
I was trying this, but the installation failed:
pip install zigpy-znp 'git+https://github.com/puddly/bellows@puddly/open-coordinator-backup'
It tells me the branch is outdated:
Collecting git+https://github.com/puddly/bellows@puddly/open-coordinator-backup
Cloning https://github.com/puddly/bellows (to revision puddly/open-coordinator-backup) to /private/var/folders/k1/bn2_hzgs3sb65wy1qpsx9_wr0000gn/T/pip-req-build-6w8vc4w7
Running command git clone --filter=blob:none --quiet https://github.com/puddly/bellows /private/var/folders/k1/bn2_hzgs3sb65wy1qpsx9_wr0000gn/T/pip-req-build-6w8vc4w7
Running command git checkout -b puddly/open-coordinator-backup --track origin/puddly/open-coordinator-backup
Switched to a new branch 'puddly/open-coordinator-backup'
Branch 'puddly/open-coordinator-backup' set up to track remote branch 'puddly/open-coordinator-backup' from 'origin'.
Resolved https://github.com/puddly/bellows to commit 11fb6d2f0954bc1339249b64f03ac3fa7dcc2ea8
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [29 lines of output]
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/private/var/folders/k1/bn2_hzgs3sb65wy1qpsx9_wr0000gn/T/pip-req-build-6w8vc4w7/setup.py", line 3, in <module>
raise RuntimeError(
RuntimeError:
This branch is obsolete! Please test https://github.com/zigpy/zigpy-cli/pull/2 instead
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
If I install it using this code it installs, but fails to run the backup (bellows):
pip install git+https://github.com/zigpy/zigpy-cli.git
File "/opt/homebrew/Cellar/[email protected]/3.9.13_1/Frameworks/Python.framework/Versions/3.9/lib/python3.9/asyncio/tasks.py", line 490, in wait_for
return fut.result()
asyncio.exceptions.CancelledError
File "/opt/homebrew/bin/bellows", line 8, in <module>
sys.exit(main())
File "/opt/homebrew/lib/python3.9/site-packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "/opt/homebrew/lib/python3.9/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/opt/homebrew/lib/python3.9/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/opt/homebrew/lib/python3.9/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/opt/homebrew/lib/python3.9/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/opt/homebrew/lib/python3.9/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "/opt/homebrew/lib/python3.9/site-packages/bellows/cli/util.py", line 39, in inner
loop.run_until_complete(f(*args, **kwargs))
File "/opt/homebrew/Cellar/[email protected]/3.9.13_1/Frameworks/Python.framework/Versions/3.9/lib/python3.9/asyncio/base_events.py", line 647, in run_until_complete
return future.result()
File "/opt/homebrew/lib/python3.9/site-packages/bellows/cli/backup.py", line 77, in backup
ezsp = await util.setup(ctx.obj["device"], ctx.obj["baudrate"], _print_cb)
File "/opt/homebrew/lib/python3.9/site-packages/bellows/cli/util.py", line 118, in setup
await s.reset()
File "/opt/homebrew/lib/python3.9/site-packages/bellows/ezsp/__init__.py", line 99, in reset
await self._gw.reset()
File "/opt/homebrew/lib/python3.9/site-packages/bellows/uart.py", line 223, in reset
return await asyncio.wait_for(self._reset_future, timeout=RESET_TIMEOUT)
File "/opt/homebrew/Cellar/[email protected]/3.9.13_1/Frameworks/Python.framework/Versions/3.9/lib/python3.9/asyncio/tasks.py", line 492, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
Nevermind, I just repaired all devices.
