I want to have an history graph with the three sensors :
temperature
target temperature
heater switch
something like the graph available in the climate card
I use an history graph and I get this (with temperature and target)
Do you know how to get the ‘step’ for the target temperature sensor instead of a line graph ?
How to reproduce the graph provided in the mini climate card ?
Did you get this to work similar to the climate card? Would you be willing to share your config as I can’t seem to access the historic target_temperature figures
Thank you - I did contemplate storing the variable, but suppose I was hoping that was a way to access the data from the history directly. I will give this a go!
Very much appreciated.
