How to rescue an entity cock-up?
I tried to change an ID on an entity by changing the name and using the functionality of selecting the check box to alter the entity ID when changing the name of the entity. I thought this would create a ‘new’ entity with the new entity ID. This did not happen.
Instead the ‘old’ entity was still there and the ‘new’ appeared as entries in the entity list all named ‘updated_state’. Now none of the entieis work.
I then went ahead and deleted the entity from zigbee2MQTT and that at first I thought that did the trick. But then I noticed that the the device is still listed in the devices page but not present in the ‘entities’ page.
I would like to make sure the device is removed so that I can add it again. But as long as it is still listed in the device page I am not sure if that is going to work? All thoughts welcome.
Cheers,
You need to remove the retained discovery messages from your mqtt broker.
e.g. using MQTT explorer
Next time you delete a device from zigbee2mqtt look for the option to delete this discovery topic too. It’s there somewhere in the confirmation dialogue box.
Thanks @tom_l !
